12 v info needed
12 v info needed
My sons friend just bought a 98 12v auto 4x4
and came running over to my shop asking to turn it up.
so i told him first get the gauges
so i will need some info on this truck
1 there seems to be 2 set screws 1 on the afc the other in the afc housing to pump . how are these taken out ? I want to adjust the afc move the plate forward and install a 3000 rpm gsk is there a thread i can look at to do all this, i dont want to go in to the pump but 1 time
we are looking to gain 65/150 hp/tq
You must be pointing at the break off screws.
I usually get the one that holds the AFC (aneroid) to the pump by drilling it out slightly and driving a T-20 tip in the pilot. I use an impact driver to crack the thread lock. If that doesn't work a hammer & chisel will sometimes crack it loose.
Once the housing is off the truck you repeat the same on the rear cover.
Here is one of the better one stop guides
http://www.cumminsdatabase.com/
yamahauler16
03-29-2004 12:41 AM
GMScott
08-12-2003 12:36 AM
