#10 plate questions,any input please.
Old 05-29-2007 | 09:19 PM
rootremblay's Avatar
I have a # 10 plate in stock position, I know I can gain hp by moving it forward. My questions are will it hurt the life of the engine, how much hp can I get by adjusting that and the star wheel, and does the intake manifold gasket have to be removed? And also I have a triple disc billet converter billet pistons and washers. the tranny has an unlimited hp warranty(to make it short) should I install a lock up switch, will it hurt anything?? and can anyone help me understand how to do that?? any help please.
Old 05-29-2007 | 10:01 PM
Sidewinder's Avatar
You will be fine moving the plate full forward as long as you have an EGT guage to keep an eye on temps.
As for the lockup switch - use the "SEARCH" function at the top of the page and search for LOCKUP or MYSTERY switch. You should find all the answers you need as well as wiring diagrams to show you exactly how to wire it up.
Old 05-29-2007 | 10:22 PM
thanks for the help
Old 05-30-2007 | 12:07 AM
Box5's Avatar
moving the plate full forward won't gain u that much more HP compared to 3/4 the way forward. Plus u'll loose about 2-3 mpg with it full forward. Leave the plate where it is and install a 3gsk, u'll be VERY happy.
Old 05-30-2007 | 02:25 PM
does 13 mpg and 15 mpg if I baby it sound right for my truck. I had a 1996 2500 4x4 (stock) it always got 17. just curious.
Old 05-30-2007 | 05:00 PM
Cowboy_Customs's Avatar
With a fully built tranny like u have, u better find out if a "mystery switch" will void the warranty on that puppy. If its as built as u say, the valve body will already lock the TC where it outta be. U may want to look into a box that controls lockup at your pre determined points, like what BD Power has. Just my 2 cents.
Old 05-30-2007 | 07:06 PM
Yeah I did a little research and Im gonna leave it be, thanks for the help. And im gonna look into the box.
Old 05-30-2007 | 11:27 PM
Sidewinder's Avatar
If you haven't already got one, the BEST thing you could do is put a 3K or 4K GSK (governer spring kit) in it. The #10 did a little on my truck but the GSK made a BIG difference. Not only made more power but MUCH better to drive in all conditions and even helped the shifting on my stock tranny.
07MCummer
12-04-2007 03:41 PM
Joe Diesel
11-12-2007 09:59 AM
SuperiorRam
03-15-2007 04:10 AM
truckjunkie
01-30-2006 10:30 PM
sCreamin400
13
12-02-2005 10:01 PM
