#10 plate and 3k gsk = which clutch to get?
Just put these in my stock 95 5 speed. The clutch slips in the upper part of 4th and 5th gear now. It's probably a factory clutch.
Which clutch should I get for these mods? I don't want anymore power. I do tow ocassionally. I don't drag race or pull sleds.
Southbend CON-O 13" upgrade will work fine, which is basically a 24V 6spd clutch made for the smaller nv4500 input shaft
Ive done several trucks, all work great for the use you describe.
FWIW Ive seen the stock 12"dia con-o slip under 100/3kgsk
archer39
09-14-2009 06:25 PM
MR HYDROSEED
03-09-2005 11:49 PM
Gymbo
11-29-2003 02:23 PM
