#10 Fuel plate. Grind my own or Buy it???
[QUOTE=kuhkuhkyle;1303228]. I myself have bench tested this plate and a plateless p pump. Both provide the exact same fuel flow of at least 400 cc's of fuel per thousand strokes of the pump, to the 110 cc's per 1000 strokes of the pump. QUOTE]
Intresting observation
But what im seeing here is this, at least what im understanding that the 10 plates dont touch the arm? heck my 100 does at 2/3 forward and even at full forward now with Governer arm adjustment, and if with a plate or not it provides the same fuel flow, then why do away with the plate and risk the damage? Its interestin how u say u have heard of some damage done to a pump, and have provided information on how it happened, so we both agree damage is not inevitable, however u can get away with no plate and still run well...
I think u can have just as much fuel with a plate if you just add some full cut DV's and a tweaked OFV, cause the limiting of fueling to the system is not in the plate itself, the real limit is in how much fuel the injectors, DV's and the fuel pressure to the system at the banjo bolt. Im not saying that a plate is not important, but in my opinion fuel pressure, and a better Lift pump system, such as an aeromotive 1000 pump, a regulator and doin away with the OFV can yield better results than running plateless,
what are your thoughts?
Rick
Rick
I agree rick. I had a 97 before I bought my common rail. I dynoed 616 horse to the ground with the plate pulled, an aeromotive 1000 pump, laser cut delivery valves, and some afc work. Thats all the fuel work i had.
I just think that pulling the plate is such an easier and less expensive way, to gain fuel flow, without any substantial side effects. And then building upon that. It's just hard for me to justify taking the time to grind the plate, or buy one when you can just pull it.
I would ask how hard is it to cut a #0 plate but I have access to a full machine shop so I guess Ive got a little more of an advantage than most...
That said if anybody ever wants a plate cut and I have the time between classes, let me know...
Let me ask a question. Keep in mind that I'm sorta 12v illiterate as to how the thing works but I know how to build it for power. But why if running plate less is so great don't the big horsepower guys pull theirs? What plate is Jim Fulmer running? I know he's got one in there just not sure which one and he did 873hp on nitrous and water/meth. Just curious.
Rick
I've heard quite a few folks tout how they've run plateless for xxxxx miles without problem but most times they eventually come back admitting that they should have listened to more experienced people.
As far as grinding the plate goes it only takes about an hour and that is when taking your time and making a mirror finish. It deffinately isn't a big deal to do and COULD save you a headache if you were unfortunate enough to break off that pin. I will probably make a dyno run without a plate next time I go just to see the difference but that will be the only time...
I'm not telling everyone out there to pull their fuel plate to gain real horsepower. But if you are Trying to buil a ton of horespwer, why not reduce any restrictions. If you adjust the arm on the rack, you'll never break that pin. There are guys actually going into the pump, and grinding another 1/4" off the rack internally. It takes them from around 400 cc's of fuel per thousand strokes, to around 550 cc's of fuel per thousand strokes. These p-pumps are actually pretty resilliant. As long as something doesnt get into the pump internally and cause a failure.
And as far as the guy thats inexperienced and wanting to go into his pump and screw it up and have someone else pay for it. Thats rediculous. Dont get into something over head is all i can say.
all you really need is a bench grinder and grind it flat
I would agree to a point. If you're going straight for a #0 or #100 plate, yes. However some of the other fuel curves such as #8 and #10 are not as easy to do with a bench grinder. It's alot easier and more accurate, IMO, to clamp the plate into an endmill and make a pass or two. I just figured I would offer incase anyone was uncomfortable doing it themselves. I usually have a pretty good amount of down-time between classes so I might as well be out in the engineering lab doing something fun.
[QUOTE=kuhkuhkyle;1305697]There are guys actually going into the pump, and grinding another 1/4" off the rack internally. It takes them from around 400 cc's of fuel per thousand strokes, to around 550 cc's of fuel per thousand strokes. [QUOTE]
Those are the famous rack travel mods we talk about here
Nothin new..
Rick
Nothin new..
Rick
Nothin new..
Rick[/QUOTE]
Then why is everyone so scared of breaking this pin, thats pretty hard to break unless you go in pull the plate and put the cover back on? I'll i'm saying, is if you want high horsepower, whats the difference. I mean sure grind your own, it isnt worth the money to buy one, when anyone can take a grinder and make it themselves.
Nothin new..
Rick[/QUOTE]
Let me throw this out.
With plate removal, would the AFC arm then act as a throttle stop? Since it just slides clear of the plate when boost comes up, the governer arm would then hit the AFC arm rather then breaking the pin.
I run the plate, and will continue, but just wondering.
gunracer1
16
02-01-2005 09:53 AM
cummins42
06-02-2003 06:00 PM
