10-12 mpg w/mach 1.5's
Old 10-04-2006, 06:46 PM
B.A.Ram's Avatar
Originally Posted by Ph4tty
Air up those tires first. Any codes? I've never had milage that bad- my worst is 15.5 with lots of black smoke and spinning duals.
Has the milage gotten worse recently or has it always been bad?
It's been pretty poor since I owned it. Like I said the best I ever got was 350 miles from full to e-light..now I don't even see that...
Old 10-04-2006, 06:48 PM
B.A.Ram's Avatar
oh and I don't have any codes...hmm maybe I just have a lemon
Old 10-04-2006, 10:34 PM
Ph4tty's Avatar
I just recall people saying poor mileage can be an indicator of a dieing vp44, but didn't want to jump the gun and scare you for no reason.
Check the tire pressure and brakes then change the fluid in the rear and if that doesn't help just slam it to lessen wind resistance
My mileage has never been great so I've just done all the above and am hoping for improvement. Ok I didn't slam it yet, but its on the list
Old 10-05-2006, 10:23 AM
B.A.Ram's Avatar
never thought about the fluid in the rear. What viscosity and what amount?? Also what do you look for on the brakes, if they were hangin they'd be squealin wouldn't they?
Old 10-05-2006, 11:35 AM
Ph4tty's Avatar
If memory serves me correctly, 75w-90 and less than 4 quarts.
I had a shop service my brakes so I'm no help there.
Old 10-05-2006, 11:56 AM
Marine's Avatar
I think its just under 4.5 qts.
Old 10-05-2006, 08:42 PM
B.A.Ram's Avatar
I think I'm runnin 45 lbs in my tires, what are you guys running?
Old 10-05-2006, 09:00 PM
dieselfan's Avatar
i run 75 lbs in front and 65 lbs in the rear.
most run 65 lbs in front and like 55 lbs in the rear.
that could be some of your problem.
dieselfan
richard
26
09-06-2007 01:35 PM
RonA
14
09-04-2007 11:09 AM
bigfish5
09-19-2006 12:56 AM
HOHN
19
07-08-2005 04:30 PM
sway825
12-08-2004 10:21 PM
Quick Reply: 10-12 mpg w/mach 1.5's
