1/8" NPT thread - 5/16" hole or 11/32" hole?
TST says to go 5/16".
http://www.tstproducts.com/pdffiles/instpy25b.pdf
Piers Diesel says to go 11/32".
http://www.piersdiesel.com/TechPyroInstall.htm
Which did you go? Which is right? It's only 1/32" difference, but still...
You can use 5/16, 21/64, or 11/32" drill bit, it really doesn't matter much for 1/8NPT, all will work. Any good tap and die set will give drill bit size to use on each individual tap. Because it is taper thread, and exhaust manifold is not very thick I prefer to use smallest bit(5/16). Grease tap, but don't cut threads down too far, or probe will be too far down. Use Vernier calipers to check depth measurement(do only little at a time), use magnet,follow rest of instructions. Hope this helps.
5/16" = .3125
11/32 = .34375
"Q or R drill, .332 or .339 for 1/8 NPT"
So the answer is "neither" Hrmmm....I'll just go with 5/16" then...depends though I might need to use my 1/4" adapter so that I can space the probe out some...
11/32 = .34375
Use a 5/16. I just did it on Friday and it worked fine. Tap called for a 21/64. I used the tap to cut the threads to fit. Just take your time. If this is for the boost guage. You will probably be drilling aluminum. If so, use grease and take your time so that you don't strip the threads.
Chris
Chris
That is true. If this is on the 97, then it has a test port that is already there and fits the boost fitting fine. It is on the side right in front of the intake horn above the Injection pump. Looks like a little plug.
Chris
Chris
Yepper...I used that one for the boost gauge already. This was for the EGT gauge.
I guess I'll just put a clock in the 3rd hole until I get a FP gauge.
Rod_Montana
12-05-2007 08:10 PM
koogala
04-02-2007 06:32 PM
swank
04-10-2005 10:28 PM
