03 track bar conversion...
A friend of mine just put some crazy lift under his 04 2500 and gave me his stock track bar.
Other than Rip, who else offers the bracket to do the conversion on the 2nd gen? (I'm asking so I can compare, I'm not saying anything bad about Rip)
the one that RIP sells is the only one that i know of that use's a factory 03 track bar with there upgrade kits.here are some links...
http://www.solidsteel.biz/
http://www.dtprofab.com/dodge.htm
http://www.thurenfabrication.com/products.html
If you have the track bar from the 04 and want to utilize it the Solid Steel and DT ProFab brackets should work. The Thuren will not as Don designed a complete new track bar with a heim joint in place of the p.o.s. ball joint from the factory.
Check the links above for pricing and availability.
and www.solidsteel.biz has an adjustable track bar that clears all front covers.
CTD2001
08-22-2009 10:03 PM
MDMIKE
11-24-2004 06:11 PM
