02 cruse control
Old 01-08-2011 | 04:55 PM
1bad02ctd's Avatar
02 cruse control
Hello new member hear. I am wondering if you could help me out I am working on a 02 ram 2500(BR) (truck in sig) the cruse is not working. I am using a 12v tps, which after a little adjustment the trans is shifting good. I have vacuum at the servo and the light douse come on in the dash win you turn on the cruse, but It just wont do any thing. I did replace the hoe servo because the old one had so much corrosion built up and still no cruse and I did check cods(there were a lot but that is expected due to ppump swap) there were 3 idle validation code that stood out to me. is that possible that is my problem?
oh i did try to search but it found no results.
thanks
Old 01-08-2011 | 08:22 PM
1bad02ctd's Avatar
guys I new hear if this is not in the right place please let me know or (mods) please move it.
thanks
Old 01-10-2011 | 01:12 PM
infidel's Avatar
Could be a bad brake switch.
Sometimes you can diagnose it by lifting the brake pedal with your foot when engaging the cruise. You have to be going at least 35 mph.
A new switch is $12 from Napa.
Old 01-10-2011 | 06:18 PM
1bad02ctd's Avatar
I did check the brake switch and the cruise did not work, so I don't know I guess I need to re look at my wiring although trans still shifts good.
thanks
oldblues
08-05-2007 12:17 AM
Evertight
02-20-2007 12:57 AM
alborada
07-22-2006 01:20 AM
xyzer
04-23-2005 02:06 AM
