01 won’t shift under hard acceleration
Help My D-max friends r comming in town and we r going to race and they out number me Ha ha I cant let them win. to get my truck to shift I half to let out of the throttle and it slow's me down big time.
Yep, it runs from the drivers side of the trans up to the Throttle control above the injector pump on the drivers side, front of the engine. Sometimes you can just bent the mounting bracket on the trans a hair and it will correct it. You shouldnt have to adjust it much if thats the problem.
easy to adjust...just did mine after putting in the trans go kit. Take off your throttle cable cover, you will see it on the bottom, carefully pull off the white locking tab, then push the cable in to losen and let it push out to tighten, then install the locking tab. Pretty easy.
The looser the more pedal needed to kick it down, the tighter the faster it will kick down and longer it will hold a gear before up shift...So I would loosen yours. It takes literally 30 seconds to do once that stupid cover is off. So you can play with it to set it the way you like. I wouldn't move it much more than 3 or 4 notches at a time....if this doesn't change it you have other issues in the tranny.
Grit Dog
14
08-26-2014 02:14 AM
89dieselkong
09-17-2011 01:20 PM
motogrommit
10-16-2009 11:13 PM
honda_guy4
14
08-15-2007 12:34 AM
