01 edge comp
Old 04-09-2011 | 03:29 PM
moparjet's Avatar
01 edge comp
i tried to search and didnt get a clear awnser.. can i run a 01 edge comp on my 00 . the map sensors connectors are diff. i can make my own or buy one..
thanks
Old 04-09-2011 | 04:03 PM
JARHEAD's Avatar
i am 99.9% positive you can. actually, i thought the connections were the same, and they were diff on the 02....also, have you seen the new (new to me) top plate for the Vp computer? makes it easier to tap the pump. Mine is not tapped till the warranty runs out.
Old 04-09-2011 | 04:21 PM
moparjet's Avatar
map sensor connector on box is a flat 3 pin.. my truck is round 3 pin
Old 04-11-2011 | 09:38 AM
moparjet's Avatar
anymore opinions???????
Old 04-11-2011 | 10:00 AM
67HotRod's Avatar
Believe the wiring is the same, just different type of plugs. Contact edge and see what they can do for you on a wiring harness before hacking into yours.
13jy831
02-25-2011 08:45 AM
lvmknsmoke..
08-13-2009 11:59 PM
mx684
13
07-24-2007 08:52 PM
JD farmboy
05-21-2006 02:04 PM
rockjeep73
03-25-2005 04:34 AM
