0 Plate
Old 04-02-2007 | 10:11 PM
Brendan's Avatar
0 Plate
I'm putting a 0 plate in this friday, what can I expect as far as egt, power, smoke etc? Also, with a 0 is placement an issue or is full forward all good?
Old 04-02-2007 | 10:15 PM
clutch1's Avatar
just be sure to check gov. arm other than that you should be good
Old 04-03-2007 | 08:56 PM
jlipskoc's Avatar
I got my 0 full forward.
my hp #, dynoed with these plates, same setup as now.
#6 plate 395 on a dynojet
#10 plate 389 on a dynojet
#0 plate 432 on a load dyno
likewise, you will need to adjust gov arm. my starwheel is loose, afc full forward also. expect lots of smoke and some drivetrain noise under low boost.
oh, no problems with egt here, if you do, just install a valet valve, see my gallery for pic. It will cut out the plate, cut hp by 1/2. I run 295hp on valet.
Looks like you have stock injectors, and turbo, you won't see any problems egt wise. Just have fun with it, if you don't like it, swap back in your 8. I doubt you will though.
Overall I think you'll gain 15-30 hp if you had a dyno before/after to compare it to.
Holler if you have any questions.
West Coast
07-01-2007 03:32 PM
plow
07-20-2005 09:40 PM
Rockcrawler
14
06-23-2005 12:40 PM
banks twinram
02-05-2005 11:38 AM
