$2000 to spend on upgrades, which ones would be the best??
I have the 300hp(60 HP) injectors, a 8" cold air intake, and 4" exhaust. What would be the best add ons for my money? I was thinking of a boost fooler with the J hook for about $120 and maybe an Edge, Banks or XZT controller??
Thanks for any and all input!
since you mentioned a j hook im going to take it that you have a auto . so first things first gauges , then i would do a valve body and converter if the the trans is fresh . you can take it to your local tranny shop and have the do a pressure check on it to see if theres any internal bleed by on aany of the seals. to make sure that your trans is healthy enough for the added stress the valve body will put on the seals
oleblue
20
03-23-2011 08:16 AM
Tim9712v
01-24-2005 06:22 PM
rmb93243
07-09-2004 01:51 AM
