yamaha grizzly
Old 02-21-2007, 09:38 PM
Twodiesels's Avatar
yamaha grizzly
Where is the best forum to discuss the grizzly 400.
Thanks
Old 02-21-2007, 09:49 PM
Totallyrad's Avatar
You're there, ask away.
Old 02-21-2007, 09:53 PM
Twodiesels's Avatar
How do i make it faster? Not a hot rod just more top end.
Thanks
But would like a website.
Old 02-21-2007, 10:17 PM
jj3500's Avatar
I'm sure you can do a bolt on exhaust, carb kit, and easier breathing intake. I've got a polaris 700. I wanted to do the similar...get more out of it. The amount of money you put into it...you really don't get much out in return. These atvs, or rather the polaris, is pretty close to max output. I was afraid of reliability after doing any sort of mods. You are out in the middle of the woods hours away from black top....you don't want any extra sources of trouble.
IMO...
Old 02-21-2007, 10:27 PM
Jeff in TD's Avatar
I'm on
http://forums.atvconnection.com/
which is OK, but a lot of threads seem to slide downhill into people dickering back and forth (unlike here, where everyone is polite and helpful).
There is also
http://www.highlifter.com/forum/
Which caters more to mudders, but I bet you could also find helpful information there.
Old 02-21-2007, 10:35 PM
06dually's Avatar
Not trying to sound like a jerk...but why didnt you just buy the Grizzly 700 if you wanted performance? I learned this lesson the hard way...I bought a Polaris 700sp and I've spent more money trying to make this thing faster..... I will say that I can stay side by side with a 800 outlander up to about 40mph...then he says goodbye.
Old 02-21-2007, 11:29 PM
Twodiesels's Avatar
Well cost for one! And I do mostly trail riding in the mountains so speed was not an issue. I am just trying to mod it a little. So if anyone has any suggestions would be helpful.
Old 02-22-2007, 06:36 AM
Totallyrad's Avatar
I was talking to member DmaxEter the other day and he mentioned a chip available for the 700 Suzuki. You might pm him.
Old 02-22-2007, 09:25 AM
Nate-03 D's Avatar
A chip for a quad? wow. I hope that is FI.
To the thread starter.
Check out this site http://www.atvnation.com/ . They are very helpful there and they have sub fourms for just about every manufacture.
You can do the basics for performance upgrades. Rejet the carbs, intake & a exaust. It's just like our trucks, the 3 basic items.
Im a little mad at my self. I went out and bought a 2006 660 Grizzly a couple months ago then they release the 700 FI w/ Power Steering,lol oh well.
I've been thinking about rejetting my carbs and all that but to be honest with you I realy don't think i'll see that big of an improvement in power. I can already get mine on 2 wheels easy enough. Not to mention 56mph is plenty fast for a 4x4 machine.
Old 02-22-2007, 09:32 AM
bnold's Avatar
One thing is most quads are jetted really small from the factory for emission reasons... My 660 and 600 (Griz) are jetted up around 4 or 5 sizes. Much better pull throughout top end and cold morning startups are much better
Old 02-22-2007, 09:36 AM
Nate-03 D's Avatar
Rejetting actually helps w/ cold starts?
My Grizzly was sitting in my garage (not heated) for nearly a month, never fired up at all. Temps were -15 some nights. Just the other day I changed the oil, diff fluid ect and went to fire it up for a drive and boy oh boy was it not eager to start. I had to realy crank it for a prolonged period of time. It's got exactly 400 miles on it and I already replaced the spark plug. Is this a normal thing?
Darn, I should of bought the new 700.
Old 02-22-2007, 09:40 AM
bnold's Avatar
Helped with mine alot! My Grizz 660 has probably close to 3000 miles on it and it always hated starting when it was cold... Not a problem any more... New 700 has too much crap to break!! power steering, EFI, other computer stuff My ATV has been under water and submerged in mud so many times the 700 would be destined for the trash heap!! My Grizz 600 was really bad about fouling out plugs... Would run great for a while and then just not start one day., replace the plug and ran like new... Not exactly sure what causes that done it since new....
Jeff in TD's Avatar
The little Griz has a carb. There's probably an ignition module out there w/o the rev limiter, but that's probably not what Twodiesels is after...
Dynojet makes a kit, that would probably get rid of the factory lean condition, and pump up throttle response.
http://www.dynojet.com/jetkits/atv/yamaha.aspx
K&N makes a filter for your application, but I'd also run a prefilter...
http://www.knfilters.com/search/prod...x?Prod=YA-3504
I would guess there would be kits to increase the performance of the CVT, too, and maybe there could be a gain to be had by moving the shift point to higer RPM. I don't know much about CVT systems, but here's an article...
http://atv.off-road.com/atv/article/....jsp?id=190895
I would guess that the best fun to $$$ ratio, and best reliability would be to leave it stock. Aftermarket stuff is pricey, and doesn't add to resale value. It would be easy to spend more on parts than what trading up would have cost.
Anyway, if it were mine and I felt the need to turn it up, though, I'd probably just go with the jet kit and maybe see about opening up the air box. It probably has a stock foam filter that already flows more than what the motor could use.
You could probably also find an exhaust can or system somewhere, but my guess would be it would be a small power gain for quite a bit of money, and the extra noise could give the anti-atv groups something to complain about.
Totallyrad's Avatar
Yes, I believe it was.
Old 02-22-2007, 09:49 AM
Nate-03 D's Avatar
I followed the link above the the jet kits. $60 bucks seems like a bargan for a little extra power and improved cold starts.
When you guys jetted your Grizzly did you notice more "umph" out of it? More low end power or is it all up top where I realy don't need it?
Quick Reply: yamaha grizzly
