Wires under Laminate Flooring
Thats MR Hoss to you buddy!
Seriously though, making a 1/8" or even a 1/4" sawcut in the top of a 6"-8" post-tensioned slab isn't really going to invite cracks...especially when your foundation is sitting on solid limestone like mine is. In clay soils where you have heaving under the slab it might be a different story, but not where I'm at.
Hoss, the problem there might be that because the laminate " migrates" up to an 1/8 inch as the temp and humidity change, there would eventually be chafing onthe wiring, causeing a failure orshort.You'd then havetotake the floor up to replacethe wires. If the grooveis run in straight runs and he leaves an access somewhere, you could replace the wiresin it with a fish-tape.
I installedalaminatefloorin our place and the instructions fromteh manufactor talk about the floor migrating and it so they require you to leave 1/4 inch of open space on each side of the floor under the baseboards.
It is probably BETTER to cut a groove, but in my opinion it isn't essential.
I had a garage built last fall. The concrete contractor came back a couple weeks after he poured the slab and sawcut it lengthwise and across. It hasn't cracked yet, although I do keep the garage heated.
If I just had speaker wire to run under the flooring I would do it as you suggested. I've got the sat cable to run as well. It's about 3/16" thick.
D-Roc
08-08-2008 04:50 AM
