What electric shaver do you use?
#31
Thats MR Hoss to you buddy!
Oddly enough, I shave faster with my Gillette Fusion than I can with an electric razor. I tried a Norelco electric once. It didn't cut nearly as close and it took longer because I kept trying to GET it to cut close. Electric shavers are worthless if you like a close shave.
#33
I see target has it for $99.00 good buy?
I've haven't changed my blades in this one yet, but my old remington used to go about a year on a set.
#36
I use a Stihl 025 16" bar with a low kick back chain....Sure it requires more frequent sharpening, but I found that my ears don't have to be super glued back on quite as often with it
#38
I use the Norelco I got for X-mas way back in 1983 when I was 16 years old. I have tried a Remington and also a new Norelco but both just pull the hairs out instead of cutting them. The old one just keeps on running. I have changed the blades a couple times but other than that it's stock... I also use a Mach 3 because the electric just burns my neck up so I actually use both at the same time. I gues I'm a sissyboy too because my skin is sensitive....
#39
I use a Braun 1775. Works great and gets the closer than the remington I had. The remington quit after 2 months of use. Got it as a X-mas present. Then I bought a Braun el-cheapo model and was surprised at how close it cut.
Jon
Jon
#40
#44
I find this one usually works quite well.... Much better than chainsaw or those goofy electric razor things... besides, when I'm done, I can go spruce up the hedgerow.
#45
Diesel Girl
18
10-06-2013 03:03 PM
Totallyrad
11-29-2010 02:34 AM
cj5er
12-20-2009 09:19 PM
mooktank
0
03-11-2006 06:20 AM
Commatoze
09-10-2004 06:30 PM
