Vehicle alarms: Who has them, pro's and con's
I'm seriously considering getting alarms for my trucks because of a rash of break-ins and crime starting to rise in my area. I'm looking at getting a Viper alarm for both of my trucks and was wondering if any of you folks have installed one before.
Thanks.
Kris
Thanks.
Kris
I have a Viper alarm in my truck, it is about 2 years old now and it is a good alarm, I have had 3 so far.
It has an external antenna high on the windshield so it has excellent range with the transmitter, I can sit in my house about 75 feet away through the walls and watch my surveillance monitor and set my alarm.
I have not looked at your alarm in question but it looks like a good one with alarms, you get what you pay for.
I also made a few modifications to my alarm, I have LED's front and rear to show it is armed, flash my relayed headlights, flash all of my relayed marker lights, I also replaced the tiny siren it came with and installed 1) 30-watt siren under the hood, 1) 15-watt siren inside the camper shell to protect my tools and a 120db ultrasonic Pain Generator inside the cab.
My alarm is so loud and has so much sound pressure that it will get you sick to your stomach if you are too close to it.
When it goes off all of my neighbors will know.
I used to install residential and commercial burglar alarms and I had a few parts left over.
You should hear my house alarm.
They are pretty easy to install, it is just a bit time consuming to do it right (at least to my standards) the only tricky part is when you wire up the relays to interface your door locks, solder all of your connections and hide your reset switch somewhere other than where they suggest it, maybe behind your ash tray.
Also don’t put all of your trust in your alarm also install yourself an additional starter interrupt switch, fuel solenoid cutoff and if you wanted to get fancy you could install a Mico-Lock to lock your hydraulic brakes, so besides your alarm going off, your truck will not start and it they tried to tow it, the brakes are locked.
That should keep it in your driveway.
Jim
Jim
I keep putting it off. Got my truck without it because I didnt want "one more thing that could go wrong". Sort of regret it and will really regret it if the truck gets stolen.
$450 bucks!! Seems like a lot but if their claims of Not One Vehicle Stolen are true, that might be pretty cheap insurance.
They can't steal the trucks with the chipped keys. As for break ins, I have a Compustar Pro and it is amazing. So far, the best range I have ever seen. Check them out...
I'm just trying to prevent the smash and grab, and adding some additional layers to what is there just to make things harder. Thieves won't mess with the complicated stuff because they know the longer they're out in the open the more likely they'll be caught.
I wanted this one since it has bump sensors and will tell you whats going on with the alarm/vehicle once it's armed and you're not nearby.
When thieves want something that´s in your car/truck, they´ll get it. But an alarm might make it a bit more difficult to steal the stereo or navigation unit. As for stealing the truck, from all I´ve rad on this site...and I´ve read a lot...Ravelco is the way to go.
Kris
Kris
Here is the site for window film.
http://www.co-opdirect.com/shattersafe.html
Thx for the link
Maybe I should start a business over here to sell the window film and Ravelco. Already had contact with Ravelco a year or two ago. I´ll have to think about it.
Kris
Kris
crossy
10-18-2007 08:48 AM
KATOOM
30
04-19-2004 07:58 PM
