Transfer case fluid drain trick.
I came up with this and it worked pretty well. I wanted to try and keep the fluid off of the skid plate. I used a piece of scrap 2" DVW. I cut a notch so I could get the wrench on the drain plug with it in place. I drilled 2 holes in the cut part and used soft steel wire to hold it around the drain plug casting. It's just enough of an angle so that the fluid runs out the end an into a drain pan. It comes out pretty fast so don't put the drain pan too close to the pipe. (I did this to eliminate a mess and caused another one instead. ) I'll know better next time.
Groovy idea. Someday I might use it, but so far, when fluid has had to come out of there I already had the skid plate off because I was pulling the tranny. Never occurred to me I might need to drain it with the skid plate on. Maybe I'm in my tranny too much.
Chris
Chris
The first time I drained mine, I just chucked the skid plate. But mine never goes off road either. That's a cool idea. Maybe Jack could put that in the tech facts section or handy tool section somewhere so others will get the idea.
Good idea, I do have some scrap pvc pipe.
Tony try a 3/4" "street elbow", should screw right into the hole. Ace or any hardware will have one. You still have to pour slowly so air can get in the case. Next I'm thinking of using a 3 or 4 inch, 3/4" nipple with a union to screw the bottle right to the case, and maybe punch a hole in the bottle while it's filling. I just can't bring myself to buy a $25 suction gun that sits around leaking all year. At least until I get some sore of "shop" set up where it wouldn't be getting moved around all the time. I'm told the garage is mine to do what I want with, until there's some crap to pile in there........ darn it, you got me going....
That's a great idea! Especially since I have had 5 qt's of ATF+4 setting on the rear floorboards for over a week that have been waiting for me to get the time to actually change it out.
thanks for saving me the mess!
Dave
Dave
Originally posted by TPilaske
Great idea!
Got any good ideas for re-filling? Man that was a pain...
Tony
Great idea!
Tony
rjm022
08-31-2011 12:30 PM
Tiger Rag
38
10-03-2006 12:14 PM
