Tire/Speedo Comparison
At one one time, before my little HD crash, I had a website marked that would show the difference between your current tire size and a new size. It showed front and side wiews and how much the speedo would be off.
Anyone know what that site might be?
I like that one, too.
Here is another one that includes gear ratio changes based from tire size. Can be a little confusing, until you realize what the intended answer is for. I have been able to fake out the formula, comparing tires/gears instead of using it to determine what gear I need to change to for the same performance.
http://www.4lo.com/4LoCalc.htm
Hope it is useful to you guys too.
Do I have this all backwards??
Originally posted by joel
OK, I'm confused. I thought if you put bigger tires on you lowered your effective gear ration (3.73 becomes closer to 3.5 going from 265s to 305s) but the gear calculator shows a ration of 3.99 when you do that.... And a 315 goes to 4.05. Of course, that's using their tire diameter calculator, but that does look right.
Ya thats showing the gears you need to keep the performance that you have now. At first I thought it was backwards so I put the numbers in the diffenent spots and it showed me what my gear ratio is with 33's.
This is my program... a little different for those who want better precision...
http://xj.cdevco.net/rpmchart
cblddt1
18
05-14-2007 08:42 PM
cblddt1
05-14-2007 09:00 AM
