tire pressure dinger
on the 1500 that I just bought I already have the light going off for the tires being low but yet on the screen they all read ok. does anyone know how to reset this dinger. Thanks
It should be in your owners manual. If it's the same as the 2500, you have to adjust the airpressure to what it says on your door post (it can be a little higher, just not more than5 pounds lower). Then you have to drive over 20 mph for at least 20 minutes, best if done on the highway. If you have the "light load tire pressure" switch, then you will need to press it occasionally while you're on your 20 minute drive until it resets itself. Sounds more complicated than it is. Hope this helps.
Shepherd57
07-07-2005 05:07 PM
electrifried
06-16-2005 11:06 AM
