Stihl saws
Stihl saws
In the market for a new saw. I was just about to buy this MS 361 when I saw this MS 441 for a GREAT deal. I'm kinda in limbo now. Anyone out there with suggestions. I realize its bigger and stuff but...any opinions.
Primary use is for private property use. I have big logs to work for heating.
The 361 is agood saw, The 441 had problems at the beggining. Don't know if they have got them right. The 361 will do anything you need it to. For more infomation on both saws visit www.arboristsite.com. I have a ms 460, 036 pro, ms 250 and other saws. i cut a lot of wood and have never found anything the 460 can't handle with the right length of bar.
Bought the farm boss with a 20 inch bar and have been happy with it, but it is heavy. Weekend warrior when it comes to cutting wood, and even less now I have moved from Alaska. Had a neighbor with the pro, and while the farm boss had about the same power, the pro was about 1/2 the weight. After trying the husky, Poulan, and Stihl, no competition the Stihl was awesome. Enjoy!
Registered
i've had a 361 for a while now. i traded two used 660's in on it and got it free n clear. I cut ~200 cord per year (not all with this saw, i have a processor) but i use the 361 to fall trees, cut tops, and anything too crooked or small to put on the processor. Great all around saw, good power to weight ratio. I havnt ran a 440, so i cant really comment on which i like better obviously. the 361 would be a beast for the occasional use home owner. And the 440 would be a bit much i would think. JMO
If you're cutting a lot to keep your house heated, you'll be happier with the bigger saw. It won't bog down as much, so you can keep a rythm going for efficiency. I don't know if Stihl switches chain size between those two models, but the larger chain will get through a few more logs than a smaller one before needing to be sharpened. The larger teeth won't heat up as readily, and are heavier gauge keeping the edge longer.
<Let the attack begin!>
chaikwa.
I thought about attaching the link that gives the appropriate meteorlogical conditions to keep it running......
J.K.
J.K.
I've got an 029 and a 044, love them both. They may sit for 2 or 3 months or more but when I grab one I know it will start. I can't say that for others I have owned.
When I'm cuttin' with my Husky, the others are stihl tryin' to start theirs!
Yes, this is true. When you don't use them, they tend to stay new.
chaikwa.
chaikwa.
LOL... I'm with chaikwa. I'll stick with my Husky, our Stihls are alright, but they're heavy, and they don't last any longer than my Husky's. Even our local tree crews have switched to Husky's.
Husky's are great saws too. It's kinda like ford and chevy and dodge. Everyone is different and prefer something that fits them, and stihl does not fit everybody. I have run both of them and would not complain about either one.
Husky on the other hand knew what I was doing with their saw and still honored their warranty. I even had to use it when the cylinder became scored. They gave me no problems and replaced the whole saw for me and I've had no trouble with the second one.
chaikwa.
