S-10 help??
S-10 help??
I have a 98 s-10 2wd with the 2.2L engine and noticed that I only show between 15-25 psi oil pressure when warmed up. Any ideas?? It shows close to 60 when cold at start-up. Also when I change oil (5w-30) would it make a difference in oil pressure if I went to 10w-30 or 40?? or switching it to synthetic?? currently has 70k on odometer. thanks
DTR's 'Go to Guy'
Nothing noticeable on the oil pressure change with thicker grades. Need to find the root problem. IIRC there is a problem with the oil galley for the timing chain. Can't remember if it caused low oil pressure or not though. Don't know why that is stuck in my head, but I remember it for some reason. Also....may want to check with a manual guage - could be a bad sending unit. 15-25 is still within specs , so I wouldn't get too concerned.
2500TurboDodge
07-31-2006 04:21 PM
