Rubber Grommets
Old 02-18-2012 | 01:45 PM
BC847's Avatar
1st Generation Admin
Question Rubber Grommets
Where can one source rubber grommets to fill holes in the firewall? I'm looking specifically for the oval shaped grommets.
Thanks.
Old 02-18-2012 | 02:33 PM
j_martin's Avatar
Maybe here:
http://www.clipsandfasteners.com/Gro...rial_s/103.htm
Old 02-18-2012 | 02:51 PM
cougar's Avatar
We just use duct tape.
Old 02-18-2012 | 05:52 PM
chaikwa's Avatar
Silicone.
Old 02-18-2012 | 10:38 PM
BC847's Avatar
Thanks for the suggestions folks.
I'm working with my boy, doing an engine-swap in his car. He's doing a bunch of stuff including a complete wiring harness tuck and well as brake-line tuck.
Doing away with the AC leaves an oval shaped hole in the firewall for example. One option he's considering is to fill those type holes with an OEM appearing rubber grommet type of plug. He's also considering simply covering the openings with sheet-metal TIG'ed into place.
(He's not in to my suggestion of painting it all satin-black and shutting the hood)
Old 02-19-2012 | 04:47 PM
SIXSLUG's Avatar
Fastenal maybe.
I like his idea of filling/covering the holes, it'll keep fumes and rodents out of his interior.
Old 02-19-2012 | 05:14 PM
Scotty's Avatar
Top's Younger Twin
Shrews are oval shaped. They will plug the hole.
Old 02-19-2012 | 06:15 PM
How about getting a round plug larger than the existing hole, and make it bigger (the hole) to match the plug ?
Either that, or get a picture of whitney huston and put it over the hole. That way, you can say I put a dead in my son's car that drew too much media attention.
Old 02-19-2012 | 06:49 PM
BC847's Avatar
I'm pushing covered with metal and sealed so as to keep with the firewall safety aspects. For some reason however, he's opposed to rivets and would rather weld them in. I confess I'm not that proficient with my TIG and thin sheet metal and know it's not gonna be as pretty as we would like.
Old 02-19-2012 | 09:39 PM
j_martin's Avatar
Should be able to tack that on with flux core (or mig) wire feed real easy.
Old 02-19-2012 | 11:35 PM
torquefan's Avatar
To fill the hole left by removing the a/c, the easiest solution may be to visit the wrecker and find the same car that was built without a/c, and take whatever the factory used to fill the hole.
Old 02-20-2012 | 09:45 AM
Shorts's Avatar
http://www.mcmaster.com/#rubber-grommets/=gbxd6e
That's just the link to a quick search. You'll probably need to dig around a little bit. But McM Carr ships quick and have a tons of hardware. Worth a look.
Old 02-20-2012 | 07:12 PM
SIXSLUG's Avatar
Fastenal maybe.
I like his idea of filling/covering the holes, it'll keep fumes and most rodents out of his interior.
Sorry, edited it for correctness!
Old 02-20-2012 | 07:37 PM
rockcrawler304's Avatar
Did this one time on a old Nova. Pulled a I6 out and put in a V8. Redid all wires. All holes were covered with sheet metal and blended in before paint. Much more work but the outcome is a hundred times cleaner and nicer than any other "Fix"
Do you know anybody else that can MIG or TIG better than you? Might be worth a few bucks or beer and pizza
Old 02-20-2012 | 08:48 PM
Totallyrad's Avatar
This won't help with plugging the holes but it may with the wiring. I just found it today while looking for some info for another member. They have allot of automotive grade water proof connectors and even firewall bulkhead connectors.
http://www.casperselectronics.com/st...x.php?cPath=53
As to the holes....
First, what kind of vehicle?
Second, Talk to Chaikwa. He uses a glue for making steel beds for trucks so they don't trap water in bad places and rust through. A nicely cut piece of sheet metal glued in place might be an option.
