Pressure washer for cow poop
Old 04-30-2006, 09:57 PM
Fronty Owner's Avatar
Adding an "on demand" water heater before the pump would give you a nice hot water supply is your able to run 220 Volt to your location.
Old 05-01-2006, 02:57 AM
jrs_dodge_diesel's Avatar
Originally Posted by strokethis600
What is so wrong with an electric one. We have electric for our hog barns and if you get within 6" or a foot it will take the paint off anything. one of the strongest washers I have ever used. However, I believe a heated water with a gas motor is the way to go. Honda makes a great motor, that is the only small motors we run around the farm. Just remember you get what you pay for.
I always had an understanding with Mr. Water and Mr. Electricity. They really don't get along together very often.
Old 05-01-2006, 06:30 AM
Commatoze's Avatar
Forget the big box stores. You need a commercial grade washer. Get something with a Honda engine and most important, a CAT pump. There are places online that will sell you this combination. The one I can think of off hand is Higher Power Supplies. A CAT pump isn't cheap, but it won't leave you hanging. It's is a little inline piston pump. The pumps on the cheaper washers are rotary. Sound familiar?
Old 05-01-2006, 10:07 AM
DTR's Self Appointed Beer Advisor
t-15 firefighter's Avatar
Honda engines are good not doubt (I've got a Honda generator) but I've had really good luck with this washer:
4000 PSI - 4 GPM - 15 HP Command PRO Kohler Engine.
Here is some good information on the engine.
Britt
Old 05-01-2006, 09:37 PM
durasmack's Avatar
Britt, I have the same washer and I run the you know what out of it..... I really like Kohler engines. I think they are great runners.
Old 05-02-2006, 09:30 PM
koogala's Avatar
Originally Posted by texasaggie2005
I know where you're coming from, that stuff is difficult. At the ranch I work for, we have a combination water heater / pressure washer unit. It operates at 6,000 psi, combine that with almost boiling water and months old manure is no match. Takes about an hour to completely clean our 40 ft stock trailer.
Don't know if we're talkin' bout the same thing but where I work we've got a
"Hotsy" Its a combo lookin pressure washer w/ a hot water tank heated by diesel. Cleans road grime, grease, pooky, you name it.
Old 05-02-2006, 10:03 PM
Ramtough's Avatar
i bought mine from northern tool. 3200 psi. was told the water heater combo ones can be less reliable due to the heating element but then again i just heard that. anyhow its been awsome and more than enough power. have to be carefull not to blow paint off stuff. just ask my front bumper.
JyRO
07-01-2005 04:08 PM
shortround
06-19-2005 07:43 AM
mooseman
03-22-2005 06:26 PM
Quick Reply: Pressure washer for cow poop
