Polishing clear plastic
Old 05-10-2004, 05:51 PM
erics76's Avatar
Question Polishing clear plastic
I'm working on a 77 chevy truck, and the clear plastic gauge cover is hazy. I'd like to clean or polish it out instead of buying a new one. Anybody know anything that would work?
Old 05-10-2004, 06:07 PM
FiverBob's Avatar
Use toothpaste and a soft rag. Rub a lot, but not hard.
Old 05-10-2004, 06:26 PM
erics76's Avatar
Thanks for the tip. Any specific brand?
Old 05-10-2004, 07:11 PM
dodgeram's Avatar
meguires makes a clear plastic polish ....... it works awsome , my dad used it on his helmet visor
http://www.meguiars.com/store_meguia...&subcatagory=1
Old 05-10-2004, 09:38 PM
Mexstan's Avatar
On a vehicle that old I would guess that the haze is probably on the inside of the plastic, specially if the previous owner was a smoker. To clean it properly would probably entail removing the cover and polishing both sides.
When you finished polishing the plastic go over it with Pledge furniture polish.
Old 05-10-2004, 10:22 PM
Nevada's Avatar
If the lens is acrylic DO NOT use a paper towel. You can buy plastic polish at your local small airport, it is used to clean aircraft windshields, it comes in an aresol can. You spray it on then wait for it to dry before buffing it off. Terrycloth works well, paper towels make the problem worse.
Old 05-10-2004, 10:32 PM
Jim O's Avatar
I use Meguires #10 to start and Meguires 17 to finish these are polishes for plexi-glass and plastic and lexon. I use them on my motorcyle windshield and my helmet visor.
Jim O
Old 05-10-2004, 10:42 PM
BigBlue's Avatar
Meguiar's Scratch X works great also.
Old 05-11-2004, 08:03 AM
jaconst's Avatar
some motorcycle motorcross stores carry plastic cleaners too
good luck
Old 05-11-2004, 08:11 AM
erics76's Avatar
The owner was a smoker, and the haze appears to be on both sides. I tried toothpaste without much result, but I suspect that the older kinds would work better, all I had was a gel type. I'll try the parts store today, not many choices here. (no motorcycle stores and airport doesn't even have a store) Thanks for the suggestions.
Old 05-11-2004, 08:42 AM
BigBlue's Avatar
Try using the paste toothpaste. Not the gel.
Old 05-11-2004, 09:13 AM
LRAmberson's Avatar
Novis plastic polish works great. Available at any commerical plastic distributor
Old 05-11-2004, 01:06 PM
erics76's Avatar
I got some 3M cleaner and polish from the parts store. It should work good, the counter guy says they mostly sale it to clean the plastic gauge covers and tail lights and it's supposed to work good. I won't be able to use it till this evening. I'l let you all know the results.
Old 05-11-2004, 01:13 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
No specific brand.....but if you use one of the "cavity control" kind it will work all of the little cavities in the plastic out. Just be sure you do NOT use the "whitening" kind....as it will turn the plastic white. "Tarter control" works good for getting that nasty film off too.
Old 05-11-2004, 01:19 PM
BigBlue's Avatar
Quick Reply: Polishing clear plastic
