Poison Ivy/Poison Oak
#31
I was told 30 years ago that if you are sensitive to poison ivy, just take one leaf and put it between two slices of bread and eat it.
You will never get a reaction again.
Does anyone know if this works?
#32
1 Post
#34
Could you imagine trying to itch the bottom of your throat ??? I guess you would tecnically be cured if your throat swelled shut and you quit breathing .
PISTOL
PISTOL
#35
One of the other workers told me that his grandpa used to make a tea out of the leaves. Would add it to his "tonic" and supposedly, would never get the itch.
Have you ever got it from the smoke when burning? Mom had the bedding on the line one time when dad lit off the fence line. If you want some extra tension from the other half, give it a try.
Ed
Ed
#36
I've heard that the smoke will really do a number on you.
A friend of mine told me of one of his friends (jr. high/high school age) who tried eating the leaves (one a day I think). Don't recall if he made the sandwich or not but in his case, it gave him a full body rash. Maybe the bread is an essential part of building the immunity but you won't catch me nibbling on poison ivy with or without bread.
I have heard good things about Tecnu. Good luck and happy scratching.
#38
There is some stuff on the market called zanfel, I have used it and its the best stuff I have used, wife didn't think it did much for her. Its about $30-$40 a tube but I think its worth it . Just my .02
#39
There was a woman in Eastern NC that died several years ago from inhalation of the smoke from a leaf pile that had some poison ivy in it. She died of asphyxiation when her throat and sinuses swole shut - they did not get her intubated in time and apparently it was too late to do an emergency tracheotomy by the time they got her to the ER. The TV and newspapers always mention the danger each fall when it gets to be time to burn leaves.
Not my idea of the way to go.......
#40
I pull poison ivy all the time and apparently its not poison to me, but i do know that when people get it, they like to get ahold of the swimming pool bleach that i use.... apparently it works really well for getting rid of poison ivy..... pour on, rince off.... repeat several times (or as my dad does after he think he gets into poison ivy, stick hands and arms into one of the 150 gallon bleach tanks )
#41
Poison Ivy or Oak is terrible stuff. It cant be imagined how bad it is by a person that is immune to it. My brother doesnt get it....go figure ? He thought it was pretty funny when I helped him dig a trench above his house when we were young....winter time dug right thru a patch of the stuff that was just sticks at the time, I got it he didnt.
I use Tecnu you have to put the beeswax based product on first before going into the stuff. Then the other is to wash it off. The cops and fire dudes get shots every year to prevent them from getting it. I tried to get the shots one year and was told its not for you go away
Almost forgot, yep have used all of the above methods bleach, hot showers, comet, abrasive products, but no one so far has mentioned gasoline or rubbing alcohol.....tried it
#42
Good responses!!
I asked the person, who told me about the sandwich, if you could die from it!!
I was told, they have seen it cure people who were sensitive to poison ivy.
I DON'T recommend anyone try this.
I am not sensitive to it. Usually only get a singe small blister at most.
The oil is the bad part of it. It is even worse in the smoke, if you burn it. My dad would just spray WD-40 in anyone around it.
#43
50-50 mix of salcylic acid and vaseline has always worked for me. for those of u that dont know when i was growing up it was called canning powder. gowing up we mixed it with alcohol. never did like the burn from that. i think one needs a prescription for it now. using vaseline does away with the burn just gets warm and stays on better.
#44
Originally posted by sherod
Have you ever got it from the smoke when burning? Mom had the bedding on the line one time when dad lit off the fence line.Ed
#45
When I was younger I had problems with poison oak/ivy. Now days it doesn't seem to bother me when I'm out in bushes. Now brother, he still has a problem with the stuff. What we use to use, and it sounds crazy, but, we would put Mud on the infected areas, instant relief, and when it would dry, wash it off, problem gone. The only thing that we could figure is due to the natural nutrients in the Mud it drew out the infection.
