One way to secure a chain in the bed of your capped pickup
Maybe this idea will help someone who needs to lock a chain in the bed like I did.
I use my pickup to carry a lot of my tools to and from my job sights. I have a cap that locks, and one of those Bully tailgate latches with a lock that I had re-keyed to match the cap locks. But, for the tools and tool chests I have inside, I wanted to lock them on a chain for a little more security. The problem was I couldn't figure out how to secure the chain to the pickup.
Since I bolted my cap to the bedrail with stainless hardware, I used stainless U-bolts turned upside-down in place of regular bolts, one on each side. So, how do you prevent someone from removing two regular locknuts? I used 1 in. angle to form a "cover". The bottom piece of angle sits on the bedrail and acts not only in place of base washers, but the bottom of the cover. The top piece of angle sits upside down and opposite the bottom one to enclose the double-nuts that prevent the U-bolt from being removed- looks like square stock when placed together. Then, I threaded 1/4-20 pan-head bolts at each end through the assembly, front to rear, to keep it together. I welded a nut on each end inside because my threads weren't quite long enough. I have stainless tamper-resistant, tapper headed screws on order that I will countersink.
If someone really wants the stuff, they'll get it one way or another. But at least this helps slow them down.
Without tamper-resistant cover:
With tamper-resistant cover:
That looks good, and with the tamper proof bolts it's going to be a long operation for anybody to disassemble everything to get to your chain.
Where did you get the clamps that hold your cap on?
AlpineRAM
AlpineRAM
The "fun" part over here is that you simply don't get those clamps, no gas springs and no cap locks... all made of pure unobtainium.
Can you PM me the contact info of the ARE dealer?
Thanks!
Markus
Thanks!
Markus
Dave88LX
04-20-2007 11:44 AM
VikingDiesel
03-14-2006 08:33 AM
