oil overfill
Re:oil overfill
[quote author=moondog link=board=10;threadid=7869;start=0#75630 date=1039041061]<br> ???Can anyone tell me if I over fill with 15 40, how much will damage engine.....<br>[/quote] <br><br><br> If your going by the dipstick readings they are often wrong.<br> What year truck is it? Most take 10qts in pan and 1qt in the filter. Some guys report putting an even 12 qts in theirs with no problem, but I will stick to 11 qts as manual suggests.<br>
Re:oil overfill
I noticed after the last change, done by the dealer by the way, that my dipstick read about a quart or more high.<br><br>Oil pressure guage seemed to be a bit higher as well, right after starting, went to normalish readings after warmed up more.<br><br>Don't know if it is overfill, or colder weather.<br><br>I guess the next time I get it changed, I'll make sure it is the right amount, then check the dipstick and maybe make a mark for the correct level.<br><br>I guess if it is overfilled and it damages anything, the dealer gets the bill since they are the ones that did it (on mine anyway).<br><br>phox
Administrator / Scooter Bum
Re:oil overfill
[quote author=Hired Gun link=board=10;threadid=7869;start=0#75704 date=1039048056]
I use 11 quarts on the money. It puts it mid way through the safe range.
[/quote]
11 quarts is what it's supposed to hold, but there's some variation in the dipstick readings.
If you used 11 with a filter change you're good to go.
If you used 12....it's a little high but nothing to worry about.
[/quote]
Re:oil overfill
One quart over dont hurt....my truck after an oil change will burn off one quart then never burn any more till the next change at 5000 miles Ive even put in 12 quarts and it only burns off one then its good to go
GeorgiaCracker
17
01-19-2004 08:53 PM
