New Toy... Electric Meat Smoker
DTR's Self Appointed Beer Advisor
Ok, first things first. I know it’s lame but I am lazy and I like to buy things that do the work for me with little effort on my part.
Just picked this up the other day and it is great. Just plug it in, set the time and temp on top, fill up the water tray, and load the wood chips in the side, and your good to go. You can set it for whatever temp that you want and it will keep it there. You don’t have to open the front door to add chips; you just load them in the side. It is nice not having to baby-sit a fire all day long (even though that is some of the fun with smoking).
Oh, I figured I would through in a pic of my daughter helping….
ToolazytocookBritt
ToolazytocookBritt
DTR's Toad Wrangler
I have a toy like that, not as fancy as yours. I smoke alot of fish. The rule is every man for himself. It does not last long.I have smoked cheese before to. Very good but hard on the waist line.
Nice smoker, Britt !! I bet the little one helps eat it too, huh ?
I like the fact that you don't have to open the door to add chips ... keep that heat in.
I picked up a wood fired smoker at a yard sale last summer but still haven't used it. Sure will be fun practicing on some fresh venison.
PISTOL
PISTOL
Very nice. Looks like something every guy should own. Do you know if you can smoke Vinison? My boss gave me 25 fresh pounds of it today. I might need some help eating all of this.
I see a bag of Jack Daniels there, is that some flavored wood or something?
If you don't mind me asking, what does a piece like that cost.
Brett,
Nice smoker
I see a problem in one your photo's that you will be needing to address before long.
No 12ft electric fence with razor wire......Before you know it those boys will be coming around to talk with that pretty girl........perhaps a moat would not be a bad idea as well
Nice smoker
Britt won't need no fence or moat, no walls with gussets for the good ole boiling oil treatment etc. He's got a smoker, a BBQ, and now he'll get a load of recipes for good stuff. Maybe we should also resurrect the cookie recipe thread and when he's tested all that with the little one she'll be a heartwarming teenager the size and weight of a chevy suburban and you don't need to worry about the boys calling
I still just need to send him some ....well, horse "parts", so when the boys start coming around he can pull them out and be putting them in the smoker.........
that'll make 'em behave.........
Brine-
Soysauce base.
3-4 cups of real-lemon juice
cut up tomatoes, onions, any other veggies you like.
real maple syrup when I have it, otherwise brown sugar and molasses.
a little worcestershire sauce.
around 3 cups of salt, I don't like it real salty. If you're working with the meat in warm weather, use the salt for treating raw meat, can't think of the name on 2 1/2 hours sleep right now.
small pieces of meat, soak 12-18 hours. Large fish or meat, 24 hours.
for another flavor, reduce the sweeteners and add terryake and hot peppers.
Soysauce base.
Britt, keep us posted on how it works, I been eyeing a smoker real hard, but its not electric. Yours looks real nice and clean.
Thanks, Tim
Thanks, Tim
Oh no… notice that I am just now getting around to posting a reply? I have finally worked out a pretty good strategy and I am finally owning with a battle rifle. I am actually a surgeon with that weapon.
Britt
Step 1
Brine your fish with this basic brine solution:
* 1/2 cup Morton's Sugar Cure
* 1/2 cup brown sugar
* 1 quart water
Stir until completely dissolved
Place fish in the solution, being careful to insure that the fish is completely covered with the brine and place in the refrigerator.
Thick chunks of 1" or more should be in brine 8 to 12 hours.
Thin chunks of less than 1" 6 to 8 hours is sufficient.
Step 2
Remove fish from brine and rinse each piece under cold water.
Gently pat dry and lay pieces on paper towel to air dry for one hour.
(After one hour you will notice the fish has a glazed film on it. This is called the Pellicle which is a normal and desired result of the brining process). When the fish is sticky to the touch it is ready.
Step 3
Smoke fish for about 2 hours at 200 F.
Use your favorite wood chips or chunks when smoking and experiment to find the taste that best suits your taste. Hickory, Alder, Apple and Cherry or combinations of these work well.
Add wood chips about every 30 minutes if necessary (depending on how much smoke taste you want.
To cut down on smoking time, remove skin from fish before putting in brine, then place fish in cheese cloth after the brine process (this helps get rid of fish oils faster and cuts your smoking time by about 1/4).
Alder wood gives you a sweet smoke that is very good for fish. You might be able to get some chunks or saw dust from a custom cabinet shop in your area.
Demodude
11-17-2006 08:36 PM
