Need Powdercoating advise
I think I'm going to powder coat my My polished aluminum Wheels I like the look. I have a place here in ohio but, I gotta figure out what type of black. I think I want a glossy black because they seem to look the best. I need opinions.
Is Patriot the light or dark. If it's light, this will help. It's not mine, but I know him from another forum. He won't mind.
http://images.google.com/imgres?imgu...n%26safe%3Doff
Powder coating is not indestructible but is alot stronger then regular paint.
It really all depends on what you personally want. i like flat black on a beat up style rock crawler/farm truck or just plain rugged look. But if your truck is really clean and never sees off road then i would do the gloss.
There is epoxy powder coat paint, that would be my recommendation. Also you might want to go through the outgassing process first before the paint is applied. That is where they will heat the wheels in the oven to a higher temp than they would when painting. This heats the wheels and expands the pores and allow trapped gas to escape. If this process is not followed, you may (not always) end up with small pimples in your paint as the gas escapes but cannot get past the melting paint. (Hope that makes sense)
Also remember that what makes powder coating so tough to get off, is that as the pores of the metal expand the melting paint sinks in, and as the part cools the pores contract and grip the paint. Powder coating can cover and smooth over small imperfections. That said, you might want to consider a very fine sand or media blast prior to the painting, this just gives it even more bite. Find a good competent powder coating facility, they should have a sand blaster and can assist you in the choice of color/texture for your wheels. I would also do an overcoat of clear.
Turbinator
16
09-04-2007 08:59 PM
Thundercloud
27
05-10-2007 01:18 PM
PanteraGSTK
01-25-2007 02:40 PM
