NEED HELP!! 1997 Chevrolet 1500 spitting and sputtering under load.
Old 10-30-2008 | 04:26 PM
HappyGA's Avatar
I have an issue with a 1997 Chevrolet 1500 2wd. Only when traveling down the road the truck will spit and sputter. It really only does it when under load. I noticed the volt meter drops to around 13.5 when this happens. This could be due to RPM's dropping, but not sure.
I have changed the fuel filter, plugs, wires, distributor cap, and rotary button. The problem still exists. I am open to any suggestions. I tried searching on google for a good forum to see if I could solve it myself, but could not find one.
If someone has any suggestions or know of a good place to look, I would greatly appreciate it..
Thanks
Old 10-30-2008 | 06:01 PM
mikmaze's Avatar
get a new fuel pump, get one from the dealer, the napa ones will not supply enough psi to pop the injectors correctly.... I had a 96 so thats how I know, the napa will run, but almost as bad as what you are describing,,,,,, the original is good for about 100 psi iirc.
Old 10-30-2008 | 06:07 PM
Copenhagenjunkie's Avatar
Just a thought but it could be a weak fuel pump. From my experience the gasser fp either works or doesn't. Have you tried turning off then back on while driving, that worked for me for about a month on my 2000 GM commuter car when the fp was going out.
Old 10-30-2008 | 08:16 PM
Spooler's Avatar
It is the fuel pump. Replaced a many of them in the 6 month time I worked at a Chevrolet dealer. Boy was I miserable. LOL
Old 10-30-2008 | 09:04 PM
Hvytrkmech's Avatar
I agree fuel pump, they should be running at 60psi, as stated go with an AC Delco, it is worth the extra money. Be prepared to spent about $300-350 for a fuel pump module.
Good luck,
Tim
Old 10-31-2008 | 08:50 AM
HappyGA's Avatar
thanks for all the help guys
oliver foster
24
04-05-2014 02:01 PM
HappyGA
11-11-2008 04:30 PM
moparguy
06-25-2007 02:25 AM
JM_1
12-23-2003 10:23 AM
Quick Reply: NEED HELP!! 1997 Chevrolet 1500 spitting and sputtering under load.
