manifold bolts pop off
My wifes 2002 4.7 started developing an exhaust leak tick on the drivers side a few months ago, but it would go away when the engine heated up. Figured out that it had popped the head off on one of the bolts. Then Friday it got a lot worse. Figured it has popped another. Yesterday I pulled the manifold and it had broken two. I bought all new bolts and gasket, cleaned the manifold with a wire brush on the drill, gently cleaned the head surface, coated the exhaust manifold bols with anti-seize and the gasket with the appropriate tack, put it all back together and warmed it up, let it cool and rechecked the tightness.
It was a pain, but I bought points with my wife!
Anyone else had manifold bolts pop off like that?
My sister-in-law used to have a older (early/mid-'90s) Geo Prism that had constant exhaust manifold problems. It actually broke the manifold itself in half. My brother found out that it was a common problem on that model and put at least 2 new manifolds on that car in the years that they had it. Be glad it was just the bolts.
Yeap, I have done so many exhaust studs on the Nissan VG30 motor it is not funny. We also would have to send the manifold out to be machined straight or put on new ones if under warranty. It was a pain in the butt sometimes if i had to drill the whole stud out and helicoil. Not a job I enjoyed that is for sure but I always got them.
Dusty Ratcliff
04-02-2006 11:08 PM
