A little gasser help from my 1st gen friends?
Hello Gents!
Need some help on my Wife's 2002 Grand Cherokee. The wipers all of the sudden have forgotten where they are. I know on older stuff there was an accentric and switch inside the wiper motor that controlled park.
Is it the same on these, or is there a controller somewhere? I don't have the FSM so I can't look it up.
Thanks in advance for any advice.
Mark
Mark
Location: North Haven,CT "Living in occupied teritory" & Barton,VT
I just had a problem with my 97 Sport. The module is in the switch, I replaced the switch and they still didn't find home. I reinstalled the old switch then replaced the wiper motor and it now works. I don't know if Grands are the same as Sports or if 97s and 02s are comparable. The other thing that wasn't working was the wiper delay. Good luck. Try Alldatadiy.com if you don't want to buy a FSM.
Thanks much! I was leaning that way because her intermittent setting isn't working right either. I'll go pick up a motor today.
Thanks again,
Mark
Thanks again,
Mark
My wifes jeep has the same problem it is a 94 grand. I replaced both the mulitfunction switch and the wiper motor and I still have the same problem. They wont park and intermittent does not work either.
REALLY old dog
i`ts an easy fix - go to a salvage yard and find a grandcherokee- in the kick pannel -drivers side _ you don`t eaven have to remove it _ gently grab the top back corner and pull out - you will see a module there about 2 in x3 in
it plugs in on both ends - get it & replace yours with it .
I did this with mine -works perfictly
before the exchange my wipers wouldnt park - & intermitant would not work !
good luck
Claude
we own 2 1994 grand cherokee limited
good luck
Claude
REALLY old dog
check behind your kick pannel drivers side- thats where you will find
winshield wiper controle module _
its simple to check - & don`t cost anything .
there were many disbilivers when i told them - including the president of the cadilac jeep club - he was amazed - knew it was there & thought it was controle for rear wiper !
give it a check - it looks like a connector to connect the two sets of wires -
really isn`t much two it
claude
claude
dieselcrazy
05-08-2003 11:07 PM
