This is kinda weird, but here it goes...
Or a variation on that idea, any old discharged fire extinguisher that has a screw-off top, empty and rinse it out, drill a hole and install a steel valve stem, add diatoms, screw the top on, pressurize from an air chuck, and spray.
You're not a Yankee, you're from NY. Heck, even Tim is just barely a Yankee!
Maine, New Hampshire, Vermont and part of Mass = Yankee. Anywhere else = imitation!
Okay, you want an idea? Here's an idea; Gravity feed HVLP spray gun. We used to use one with the delivery hole bored out a tad to LIGHTLY sandblast brass pump impellers and/or housings prior to spray welding. If it will deliver sand blast sand, it oughta deliver powdered earth. And you can control the pressure, volume and spray pattern right at the gun.
Now he won't have a spray gun!~
Quit drinking??? Thats kind of a low blow don't ya think? Gee Wiz I was simply asking for help, and you chimed in with a smart aleck, demeaning comment. But hey, if that means I am easy to wind up so be it...
I am just trying to save some money and come up with a solution to a problem.
yup, same thought. we use a fire extinguisher to powder the pear and apple trees. use to use a pastry bag (think decorating cakes) for the rescue dogs to powder for parasites without scaring the animal. nice hand controlled puffs so we didn't get overwhelmed, but coated the animal's skin very nicely. depending on how many heads of cattle you have to do....fire extinguisher would be a good, simple dispenser; refillable from the air compressor and changed out for the type of vectrine you need....
we use 40 lb pressure for the trees to coat even with wind blowing. about a 16 inch circle each pull/dispense.
from a yankee
from a yankee
I think I could take a pastry bag put a cup or two of DE in it, wrap the open end around an air nozzle and just lightly puff air through it. Might be a place to start anyway. And very cheap and easy to rig up!!!
Using water is not really an option as it makes a huge mess (lots of clay and poop), and we would have to run two hundred feet of hose to get it to the chutes.
Thanks for all the ideas guys, I really do appreciate the input!!! Keep them coming though!!!
That makes you an official Yankee RedNeck
Maybe that was true back in the civil war days. Not so much now. Heck anyone south of Jersey has a southern accent now and says 'yall'. Yankees do NOT say 'yall'!
And that's different from any other response I've made to you... HOW? I thought from some of your past comments to me that you and I were okay with jabbing each other back and forth. Guess I was wrong. Rest assured it will NOT happen again and I apologize for any duress this has caused to you.
WOW!!! that was EASY!!!!
I never figured in a million years I would get you to capitulate that fast!!!
Hows that for 'flat lander' ingenuity!!!
Somehow, and I am not sure how, they seem to know that they are being sent away, and get cranky.
Maybe the alien cow abductors have implanted mind reading devises in them, probably why they seem so disinterested in me after a couple of seconds...
