kerosene heaters w/diesel fuel
Old 01-18-2007, 01:50 PM
stock03's Avatar
Question kerosene heaters w/diesel fuel
Does anyone know if diesel fuel can be used in a kerosene heater?
Any benefits or drawbacks, besides the price of diesel being a lot less than kerosene.
Old 01-18-2007, 01:54 PM
CARR's Avatar
We used diesel in ours after a while they seem to clog up and quit working.
Old 01-18-2007, 02:35 PM
Scramblinman's Avatar
That what I have heard as well. The diesel is a less pure, lower cut of the refining process and does not wick up as well as kerosene nor burn as clean.
Old 01-18-2007, 03:07 PM
butchb's Avatar
If you're talking a torpedo heater, then pump diesel #1 or #2 should work. If your talking a wick type, Kerosun ect. They should only be run on K-1 Kerosene. Diesel fuel will shorten the life of the wick a lot!!
Old 01-18-2007, 05:42 PM
stock03's Avatar
I'm not how to tell if it's a torpedo heater or not. It's cylinder shaped and sits on top of a 5 gallon fuel tank. It's noisy but blows a lot of heat and warms a 3-car garage with ease.
What's a wick type?
Old 01-18-2007, 05:51 PM
stock03's Avatar
...Ok, just found out that the heater is a torpedo. I'm going to try diesel fuel this weekend. Looks like we're getting a snow storm out here in NM.
Old 01-18-2007, 05:54 PM
Administrator / Scooter Bum
Shovelhead's Avatar
What's a wick type?
Wick Type..............................Torpedo
Old 01-18-2007, 05:58 PM
Geico266's Avatar
Diesel works just fine in a torpedo heater, been doing it for years. No problems at all.
Old 01-18-2007, 06:14 PM
stock03's Avatar
Great info..thanks guys. Shovelhead, thanks for the pictures.
Then diesel it is!
Old 01-18-2007, 06:29 PM
Shovelhead's Avatar
No problemo.
I have a 55,000btu torpedo that I use to heat my garage.
Yeah it certainly IS noisy.
But in 1/2 hour, it will raise the temp inside the garage 30 degrees.
Old 01-18-2007, 06:36 PM
ofcmarc's Avatar
No problemo.
Heck, at -45* 1/2 hour with one of those will thaw out a gelled truck and get it started again.
Old 01-18-2007, 06:39 PM
Shovelhead's Avatar
...and burn all the paint off the truck too......
My garage is cinderblock 30' X 30' with 10' ceilings.
Old 01-18-2007, 06:50 PM
BearKiller's Avatar
Before you get too carried away, some torpedos can burn Diesel, and some will not tolerate it.
I have dumped diesel in a couple different ones to have them quit and have to be disassembled and cleaned, before they would work again.
Also, diesel puts off a much stronger smell.
If it will abide diesel, without gumming up the works, then by all means, pour it to it.
The only drawback to torpedos is they are like standing next to a jet engine at full throttle, sort of head-splitting.
Old 01-18-2007, 08:04 PM
kelley15's Avatar
Down here we call the torpedos , "salamanders". They run fine on red dye #2.
Old 01-18-2007, 09:04 PM
Fronty Owner's Avatar
We run #2 in ours at work. but thankfully, we are moving into anew building and dont have to use that noisy, stinkin' thang no more...
Quick Reply: kerosene heaters w/diesel fuel
