Jerry Cans
Jerry Cans
I have several old military gas-cans.
I also have two of the after-market spouts that have the flexible metal hose that looks like flex-metal-conduit.
These cans have a vent hole located under the rubber gasket of the screw-in lid that is exposed when the spout is screwed in.
There has got to be a better way of using these cans than I am doing.
It is impossible to pour gas from them without most of it running out that vent-hole and pouring in my boot , or on the ground.
Is a better spout available??
Is there a way to pour from these cans without getting a gasoline bath??
If I can't find an easier solution, I am going to drill a 5/8" hole in the opposite end of the top of the can, and install a tubeless tractor-tire valve, to act as a vent, then I am going to plug the little vent hole that is near the lid-opening.
I know that will cure the problem.
Any help, or advice, is appreciated.
Thanks.
I hate Donkey <EDIT> they are called that cause all they are good for is leaking fuel all over your boots. you need to ensure you have a good seal on the fuel neck if needed shim the locking bar with a dime on each side to tighten the ruber crush sleeve when you lock it down. That usualy helps, we used to use a small thim piece of metal in a u shape to shim the fuel necks
Edited by Admin
Edited by Admin
Urban Legend
Well, it looks like I am not alone in getting my boots full when trying to pour from a Jerry-can.
I kinda half-hoped that there was a better spout, or method of pouring.
I guess I will go ahead with my alterations and see how that works out.
I will drill a 5/8" hole in the top, in the opposite end from the opening.
I will fish through a brass tubeless tractor fluid-fill valve stem.
Then, I will tap threads in the existing vent-hole, and screw in a plug.
When I pour through my spout, I will unscrew the fluid-fill opening of the valve.
It should work like a charm.
Thanks.
Get them here, best cans you can buy, no leaks, and have a vent for pouring.www.sportsmansguide.com
I like the flat-sided shape and, as I have a tire shop, the valve stems are sort of a perk of having the business.
Those Spostsman Guide cans look pretty good.
Maybe I will add a few of those to my collection.
Thanks.
