how to cure algae issues in your pond
I have 50' by 50' pond and am being over run with algae. What is the best way to get rid of this stuff or at least control it. Is there a good solution that you can mix in with the pond water? My fountain broke, hence no water movement which = a crap load of growth.
If anyone has a pond and knows of an effective way to deal with this, let me know.
Thanks
Tom
Thanks
Tom
DTR Mom
I even know where cannonsburg is!
alum- at the farm supply places - makes the dirt in the water clump together, get heavy and sink, balancing the ph and bottom alkaline at the bottom of the pond. rids algae that way BUT try the 20 dollar solar powered
(fan blade) circulator. you have to have something to create the balance.
i have koi in a three quarter acre pond by 16 feet deep. no algae this way,
thanks to the koi too.... hope that helps.
movement or high alkaline plants at edges for simple control.
try to look for an old pool filter if you have electric nearby...
my dad is in a "fish pond club" and those folks all have advise & free Koi for each other,
no idea how you would find one in your area though, maybe ask at pet fish stores?
most folks with small ponds over breed, and keep just the pretty koi
when ours was overrun when my parents had their place we always used copper sulfate. we had a little strainer setup where you would introduce water from a garden hose into one end of a special holding tank that contained the crystals. then we just shout it out of a nozel out across the pond. did it ever month or so and it killed the stuff dead.
Thanks
Tom
Thanks
Tom
Check this out, Scott is an old friend of mine:
http://www.proskim.com/
hey guys thanks for all the feedback. I should also mention, I am trying to do this as inexpensive as possible. I have a fountain that circulates the water well, but has been down for about a month. Come to find out some critters chewed through the electical and caused it to short out. i spent the better part of the day working on it and got it fixed. I spent the last two hours with a rake pulling the crap out of the pond. I made some headway... I am however not ready to put the fountain back in the water, for i fear it may end up getting clogged. ($1600 fountain, not ready to replace it. ) I just need to find some chemicals that I can put in to take care of the rest. Fish friendly too, as I have large mouth bass and catfish swimming around. Ill check out some of the things mentioned. Keep the advise coming. Thanks again.
Tom
Tom
it never did a thing to our fish. we had catfish and bass as well as some crappie and we never once had any die on us. given we didnt completley load the water with the stuff. we didnt just let it run all the time, like maybe a 15 min spray every month or so.
i used to see the frogs and small fish jumping out of the ditch water and onto the ground. i don't know about catfish . good friend has a 3 acre pond just down the road from me an i have supplied him with barley straw for five years and we put 25 bales in and the algea and trash have been way better.
Copper sulfate does not hurt the fish. What kills them is the copper sulfate kills the alge and it uses up oxygen when it decomposes and that suffocates the fish. If you have a bad problem you should only treat part of the pond at a time and keep the fountain running to keep oxygen level up. If you do not let it get to bad you can treat the hole pond and not harm the fish. I put about 5 pounds of copper sulfate in a burlap bag and tow it around the pond with a boat untill it all desolves. That is for a 1 acre pond.
