How bad is this for my tires?
Working on the injector pump R&R, or any truck with big tires, I like to air down the front tires to make the truck kneel and have better access to everything. Just yank out the valve cores and drain 'em.
How bad is it to leave the tires like this? Not forever, just for a few days or something. I don't really feel like taking the wheels off to put it on jackstands to lower it...but I will if it's that bad for the tires.
You'd be surprised how many shops do this on the taller or lifted trucks. I've done it on occasion for injector swaps and such. Haven't had a tire problem yet.
Jeff
Jeff
I was just thinking of the way the tires are aired down on hardcore offroad vehicles. Granted, the tires gets moved around so the belts dont get set in a certain bind.
Not all off-road tires are bias ply. On my TJ, I have MT/rs and I air them down to about 4-8 offroad. To be honest, if you don't go as low as to blow the bead, I dont see how it would be THAT bad for it.
A flat tire, radial or bias, that sits with the weight of the vehicle on it for more than a few hours will, probably, develop a "bruise" that will show up later as a seperation, probably months after you have forgotten about letting it sit flat.
I have seen many sidewalls crack open, after sitting flat for a couple of days.
I know some have done this and escaped unscathed; but, it is not a good habit to develop.
I never do this, but if nothing else, put jackstands under it, and then let all the air out of the tire and have the jackstands just hold the rim barely off the ground.
Eric
Eric
OK thanks for all the suggestions guys, based off what you guys and some other people said, I'm just gonna set it down on jacks. I just hate having to re-torque all the stupid lugnuts on this thing!
