Hole in Firewall
Old 05-12-2003 | 12:44 AM
clifford's Avatar
Hole in Firewall
I have 2003 2500 4X4 can I drill a 1/2 hole through the firewall between the 2 bolts about 6 in. above the hood release cable. Looks like just a plastic plate in the eng. comparment, or is there a better place to go through.<br>Thanks
Old 05-12-2003 | 07:13 AM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
Re:Hole in Firewall
Thought the subject was &quot;Fire in the hole!!!!!&quot;.<br>Better go clean my glasses. :-[
Old 05-12-2003 | 07:44 AM
butchera's Avatar
Re:Hole in Firewall
If you have an auto, just drill a hole in the cluch hole cover. Works real good.
Old 05-12-2003 | 08:28 AM
bulabula's Avatar
Re:Hole in Firewall
There is already a hole and grommet on the firewall near the clutch pedal. Worked great for me. I'm sure its there on auto's too. No drilling required.
Old 05-12-2003 | 12:46 PM
FiverBob's Avatar
Re:Hole in Firewall
[quote author=bulabula link=board=10;threadid=14623;start=0#137158 date=1052742486]<br>There is already a hole and grommet on the firewall near the clutch pedal. Worked great for me. I'm sure its there on auto's too. No drilling required.<br><br><br>[/quote]<br><br>Yep, worked on mine. Right by the steering column where it goes thru. Little sharp knife and you have a hole. <br><br>KISSBob (hmmmm, better be good lookin' blonde )
Old 05-12-2003 | 12:59 PM
Commatoze's Avatar
Re:Hole in Firewall
If the grommet is the same as those found on 02's, you can pop it out from the firewall from under the dash and work on it directly.
Old 05-12-2003 | 11:02 PM
clifford's Avatar
Re:Hole in Firewall
I can't find the grommet on mine. I think I will drill in the cluch cover.<br>Thanks
Rauschbo
04-15-2006 08:15 PM
GO 4LO
11-01-2005 03:59 PM
Dave88LX
09-13-2005 11:45 AM
Planetcat
06-28-2004 04:20 PM
