Help support this website!
Guest
Posts: n/a
If you pay attention to the stats at the bottom of the forums list, you will notice we have a very healthy menbership, and growing steadily and impressively! Add to that the fact that frequently the number of visitors exceeds that of actual members, and we have a significant force of numbers working for us.<br><br>If you see and subsequently purchase a product you saw mentioned on this board, why not mention that fact to he outfit you are buying from - it reinforces the confidence of those already helping support this group - and MIGHT influence new advertisers to help support us. All it takes is a "I saw your product mentioned on the Diesel Truck Resource website" - sure might help the future growth of this EXCELLENT site! ;D ;D ;D<br><br>[move]Support this website - say "I saw it on the DTR!"[/move]
Re:Help support this website!
Gary, Good idea i will pay attention to it better,as soon as i have some money to spend ;D i will give you kudoo's on your air box mod for the stock air box. it worked great and gave me 2mpg's more but it was to noisey so i plugged them until i can figure the air tube stuff out to get the air in there and the noise inside the fender well. i will let you know if i come up with it. ;D
Guest
Posts: n/a
"it worked great and gave me 2mpg's more but it was to noisey so i plugged them until i can figure the air tube stuff out to get the air in there and the noise inside the fender well."<br><br>HMMmmm - that's strange, I didn't notice ANY change in noise level at all - might just be my lousy hearing after too many years around heavy/noisy equipment... I did leave my stock airbox otherwise stock tho, still uses that thru-the-fender air tube... Still using the K&N, installed used and slightly dirty from the first owner - filter minder still sits at lowest percentage of restriction after about 10,000 miles use... ;D ;D ;D
yep it sounded like a heat manifoild on a gas engine does ,sortof. i will be working on it though.getting the ctd changed over to amsoil in the tranny today. ;D
Mark Thomas
04-03-2005 07:23 PM
