help. 2003 duramax 3500. white smoke at idle
hey guys my buddy just bought a 03 duramax. smokes white at idle. fuel filter recently changed. any ideas?
What were the codes and what mods are done to the truck. Is this smoke just after start ups when cold or all the time even when warm. Does it smoke at all driving down the road. How bad is it smoking alot or alittle. White smoke on diesels is pretty much injectors. If cold on start up and then goes away that is normal.
Injectors, but if he's using a little coolant with it, i'd say he might have some leaking injector tube o-rings-somewhat common on that engine. How does the truck run overall-any surging or misfires. Really need more info, also what code number was it?
the only code we got was a turbo boost performance code. it smokes only at idle cold or warm. when driving no smoke. truck is stock although it looks like maybe there was a chip in it at one point as we found a piece of velcroe on the fuse box so maybe someone had a chip on there. it has a full exhaust and a cone air filter.
were leaning towards injectors though.
Macc878
01-15-2013 03:40 PM
mattyfz450
02-02-2009 10:40 AM
Stroked-Z
10-04-2008 11:28 AM
Common
09-30-2008 11:25 PM
