Have Spark Plugs Improved
Old 07-30-2013, 12:24 PM
irocpractice's Avatar
In the last 42 years or so? That is the last time I fired this engine. At one time Champions were good for about 7/8 thousand miles,and NGK's would give me about 11/12 thousand between tuneups.I am looking at Champion BPR6EGP's or NGK RN12YC's as I do want to stay with copper.I could go with platinum but then I would have to add an MSD for more power across the electrode.And why can't I get non-resistor plugs today?Sheesh,I ask the counter person and get a blank look like their nose fell off.
Old 07-30-2013, 03:21 PM
railroaderone's Avatar
The resister plugs just reduce the noise in the electronics and don't harm performance any
Old 07-30-2013, 05:11 PM
Ah yes RR1, I do indeed see that you are a little younger than I am.I always found that if I tuned to the right station I would not hear the buzzzzzzzzzzzz so much.Besides as loud as the exhaust is I can't hear the radio (AM only) anyway.[Now I gotta find baby some new shoes,185x70x15 Vredestin"s,or 180HR15 Michelin XAS:s ?
Old 07-30-2013, 05:16 PM
Administrator/Jarhead
madhat's Avatar
Sp...sp.... spaarrrrk pl...pluggggs?
What are them?
Just get a cheap plug that is a little hotter than you need... it'll be good. Champions are pretty good, I run them in the hemi, don't have any problems.
Old 07-30-2013, 05:51 PM
Bark's Avatar
Seems like spark plugs started lasting longer when they went to electronic ignition.
Wonder if the newer digital electronic ignitions make spark plugs last even longer.
Old 07-30-2013, 06:48 PM
j_martin's Avatar
What used to kill spark plugs was lead fouling from the tetraethyl lead in the gasoline. Since unleaded gas came in, and with tight engines, there really isn't any deposit on the plugs, and electrode erosion is the main mode of failure.
Old 07-30-2013, 07:40 PM
Rob's Red Ram's Avatar
All I use in my lawnmowers,snowblowers,weed wacker etc is NGK.Never any issues.
Old 07-31-2013, 12:15 AM
NE frmhnd's Avatar
RN12YC is a Champion number, it's what my 87 2.2L Dakota called for. It used oil and the first time I didn't run it long enough to get up to operating temp, it fouled them, and they never would come back with a cleaning. Finally got to the parts store and got Autolites before dad could get me (another) set of friggin Champions, and ran the thing another year and a half on that set, instead of days.
I think they crossed to an Autolite 65.
I haven't used a Champion plug since about early 1998.
Old 07-31-2013, 12:42 AM
Bark's Avatar
That's interesting and makes sense. I remember seeing cat converters and unleaded gas coming on line sometime around 1975 the first year I heard about electronic ignition.
Sometime in the early 90's I got bummed because I couldn't find leaded gas anymore for our 57 Buick.
Old 07-31-2013, 10:04 AM
patdaly's Avatar
If I ever wear a set out on the 02 Crown Vic I will let you know, 153,000 miles and counting on the original set. Still shows 0 misfires................
Old 07-31-2013, 10:51 PM
j_martin's Avatar
If you pull one and look at it, you'll find the gap has eroded way past specification.
If you continue to run it till you get a misfire, the misfire will be caused by overvoltage destroying something a lot more expensive than a set of spark plugs.
Old 08-01-2013, 12:08 AM
Cummins610's Avatar
2011 hemi has 155,000 miles and 2008 grand caravan has 200,000 miles. Both still on factory plugs.
Old 08-01-2013, 06:39 AM
j-fox's Avatar
A champion 12xx plug is too cold.
I used 15xx on my trucks years ago.
11xx and 12xx were used on high compression muscle cars many years ago.
I don't care what the champion charts say I use what experience proves.
Old 08-01-2013, 10:56 AM
Somehow I think I am tending toward the NGK"s.Last night I did the second Stromberg HS 4,now for the third and final one.We did mill the head and bump the compression up to about 9.5 and added hardened valve seats.I have no idea what today's "gasoline" is,but it sure ain't what we used to run.
Old 08-01-2013, 06:43 PM
Bark's Avatar
Used to be made from fermenting dinosaurs.
Now its made from liberals poop which really screws up your system.
Quick Reply: Have Spark Plugs Improved
