Getting into welding, few questions
I am looking to build a tube chassis rock crawler and make my own bumpers for my trucks and similar projects like that, I was wondering if this machine would be able to handle the projects i have in mind.
I am posting pictures of projects i have in mind (examples)
here is the machine im looking at..
Miller Syncrowave 250
http://store.cyberweld.com/milsyn250dx.html
http://www.millerwelds.com/products/...rowave_250_dx/
For projects like that it might be a bit big. But it's better to have it and not need it that to need it and not have it. It's quite a chunk of change, but it's probably worth it if you plan on using it alot.
yea, thats a nice tig. even the miller 180 is plenty tig for that kind of work. I recently bought a mm175, and it does anything i can think of except aluminum because I don't have the spool gun, but I didn't get it for aluminum work. Tig is nice for small stuff that you can put on a work bench or have level access to. But I enjoy the mig being able to weld in any position with a second hand free if needed, plus tig is hard, lol.
a couple others to check out would be
ThermalArc 185
HTP invertig 201
Miller 180SD
Lincoln Precision Tig 185
ThermalArc 185
HTP invertig 201
Miller 180SD
thank you guys.
P.J. you have any recomendations for tube benders? i have a friend who can bend up to 2" tubes but i dont want to have to rely on him.
also, any recomendations for a plasma cutter?
DTR's Toad Wrangler
All you need is a DC machine 200 amps or less, a flow gauge, and a tig torch. I am sure most of this can be bought used and possibly under $800. With the savings you will need a cut off saw and a pipe bender that you can use with a hydraulic jack. As your experience and jobs grow then you will be able to get the fancy toys.
Being that you are just starting I would suggest you get a mig first and then go for the tig. The mig is much more user friendly and way faster.
With a tig you can control the temperature much easier. If you've ever used a gas welder it's the same basic procedure. I really like tigs and would buy one if I knew I'd use it alot. A mig is alot more versatile though. Not as pretty when it comes to welds, works good though
I would agree and get a MIG, they are very user friendly and with enough practice will be able to lay an un-breakable bead in any position. I make bumpers and other custom fab stuff from time to time and I will tell you patience is the best thing to have IMO.
The only reason is temperature control. That way you know your getting a consitent weld everytime. Also, if your going to spend the big bucks on a tig get an AC/DC. That way you can weld aluminum. Straight DC is ferrous only.
