front tire issue...
front tire issue...
The inside Inch or so of the front passenger side tire is bald. The rest of the tier is still about 90% good. What would cause this? Tire pressure is good and the truck was aligned not too long ago? Any ideas?
Received 1,647 Likes
Your signature doesn't contain your vehicle information, so that would be helpful.
Urban Legend
Administrator / Scooter Bum
I prematurely killed the edges of front tires on my 2WD dually by taking exit ramps like I was driving a 6 wheeled Porsche.
(Tread rolling over)
MAN those things will corner................
Running SUV rated tires on the front end will make it wear tires looking like under inflation.
We need that heavy sidewall to support the mighty Cummins.
4WDs will wear tires quicker as there are many more moving parts that wear out.
Is this on a Dodge/Cummins or a Geo Metro?
A 2013 or a 1913?
These are some of the reasons that folks ask what kind of vehicle you have.
It's like telling your doctor "It hurts" and then get your feathers ruffled when he asks "Where or When?"
A 2013 or a 1913?
Fair enough... Its a 93 3500 dually 2 wheel drive with one billion miles on it. Actually only 325,000 miles and not on the original tires. Tires are all e rated. These tires have seen nothing but old man highway miles with exception of drifting the on ramps. LOL
A 2013 or a 1913?
A 2013 or a 1913?
....I thought I was the only one taking,,, off ramps like a bat out of hell....
I was complaining to a friend the darn tires where "chipping" away...Until I took him for a ride...on some off ramps..
He said the same thing...it's a truck...not a sports car.....That's why the tires are wearing on one side...
The duallys do corner good...even in a 4x4...Corners even better now..Since I lowered all 4 corners.....
All of these issues can cause the inner tire to "SCRAPE" as you're taking turns, vs rising up and down in it's own axis. Scraping of the tire would explain why it's worn out on the inside, and no where else.
I stand by my previous answer, and I'll add... Control arm bushings, worn out springs, Ball joints and a loose nut behind the wheel.
Whenever I've had a shock go bad, a wear pattern called "scalloping" develops on the tire. It's where you will see a repeating pattern of high and low wear on a tire lug, inside, outside or center of the tire tread. I guess it's also called a "Saw Tooth" wear. At least that's been my experiences.
This visual guide basically says that the issue is most likely Camber, but again, it's usually a combination of worn parts and alignment issues that are the ultimate cause.
http://www.monroe.com/en-US/support/Symptoms/Tire-Wear/
From experience, when the front end is in good condition and properly aligned, and it's driven by an old phart, the tires wear very nicely.
I have been known to get impatient enough to completely smoke out an intersection. Not very often, though.
I may be getting older, but I refuse to grow up.
dan123dbl
02-13-2015 05:47 PM
Dave88LX
14
09-01-2011 11:36 AM
Scramblinman
10-16-2006 05:36 PM
