factory fog bulb replacement ..
how do u get your hand in there to twist the bulb to pull it out. i didnt full with it to much 2nite, just popped the hood and looked in with a flashlight. i expected alot more room in there. is it easier to reach up in from the bottom ?? thanks scott
Dieselcrazy:
Remove the batteries and loosen the battery box - that will give you enough room to get your hand in there. Just did both my headlights and it worked great. In addition to the bolts inside the battery box, there are two that you access from under the front end on my 98. Easy 10 minute job.
Sorry, just noticed that you were referring to the fog lights and not the headlights!!!! DUH!!!!
John (DH)
John (DH)
Factory fog lights are replaced from underneath. Lay down reach up and turn bullb assembly 1/4 turn should come right out then pull off wire connection. Hope this helps.
ok i kind of figured that would be the case. i guess ill have to go down moms and pull it in the garage so i can lay on the floor... to much snow and ice here
scott
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
robert78.5
09-28-2007 10:23 PM
03CTDCO
04-10-2005 11:10 AM
Hummin Cummins
02-04-2003 04:26 PM
