DTRs Breakroom: Gentlemen, start your engines!! 3/29-4/4/09
#482
#483
ok, time for more chainsaw talk...
I suspect its tuneup time on my husky.
I have run probably a gallon and half of fuel thru it, but I have no idea how many hours of actual run time. The air filter is looking a bit dirty but not what I would call "bad". the saw has been running fine all day and started acting up a little while ago after running for a while. The saw will idle, but will bog and stall when I pull the trigger. when it cools off, I will check the spark plug.
Any ideas?
Any ideas?
#485
about like I always do. let it ride in the back of my truck and a slight shake of the can.
how long does it take for the fuel and oil to seperate.
#486
REALLY old dog
How Does The Plug Read ? That Can Tell A Lot- Hot
You Said The Air Cleaner Is Clean- Not Chocking The Engine
WHAT DOES THE BLADE & BAR SHOW ?
IS THE BLADE GOOD & SHARP
IS IT RUNNING SMOTH IN THE BAR -NO BURN SPOTS ON BAR-OR BURS ?
#487
Afternoon all. Had some Jack in the box...aka..dirty box today.
It isn't treating me so well. I had some of their toothpaste tacos. Oh man.
I don't think I'm going out tonight. I need a break.
#488
I have seen dirtier air filters, just dont know how tolerant a small engine is of dirty air filters.
Blade and bar aren't showing anything that I can tell. the chain was about as tight as I usually run it. the saw would stall before I even touched wood. just sitting there, it would idle, but start to rev and it would bog and die.
On a side note, this is the hottest day I have run the saw.
ok, I got a look at the plug, there is some carbon build up around the outside near the threads, but the ground strap and electrode are all the dull brown carbon that is normal.
just drink whiskey tonight... it will take care of what ails ya...
#489
REALLY old dog
Are You Sure That No One Has Used The Saw Gas And Replaced It Not Realising That It Neaded Oil ?
Clean The Air Cleaner And Dry It Good And Give It A Try
Still Realy Consurned About Oil Though - I`ve Had This Happen- Had To Replace Piston & Cyl.
IF THE SAW IS RIGHT YOU SHOULD BE ABLE TO USE IT AT 90 TO 100 DEGRES -IF YOU WANT TO
#491
REALLY old dog
YEA -YEA -WE KNOW - YA GOT SOME JINGLE IN YOUR POCKET - ITS SPRING - AND YOUR BRAIN SLIPS DID I SAY THAT
BEEN THERE AND DONE THAT - WAS A TIME THAT I PARTIED 6 NITES A WEEK & SUNDAY AFTERNOON HOUSE PARTYS - WHILE HOLDING DOWN A FULL TIME JOB.
(MATTER A FACT I WORKED SO HARD AT PARTYING IT BECAME A JOB)
AFRAID SOMETHING IS GOING TO GO ONN & YOUR GOING TO MISS OUT !
HAVE FUN- SAVE THE PIECES -YALL HAVE TO PULL THEM ALL BACK TO TOGHER BY MONDAY AM
CLAUDE
CLAUDE
#492
I can dump the fuel in the tank and try again. It should be good fuel, I got it just before I went to WI and have run one tank full without problems.
http://i74.photobucket.com/albums/i2...w/100_0084.jpg
inside the filter http://i74.photobucket.com/albums/i2...w/100_0085.jpg
outside the filter http://i74.photobucket.com/albums/i2...w/100_0086.jpg
the wood pile http://i74.photobucket.com/albums/i2...w/100_0091.jpg
I didn't embed the images because of the size.
#495
REALLY old dog
WELL I DON`T EITHER - IVE TAKEN THEM APART AND REPLACED PARTS PUT THEM BACK TO GEOTHER - BUT JUST USING COMMON SENSE ON WHAT I DOING - WAS IT DONE RIGHT - I DONE KNOW -BUT IT WORKED
2CYCLES ARE AN ANIMAL OF THEIR OWN.
JUST SOUNDS LIKE THERE IS SOMETHING DRAGING -2 CYCLES DONT MAKE FUNNY LITTLE NOISES LIKE 4 CYCLES -SO THER HARDER TO DIGIONOSE FOR ME.
GOOD LUCK WITH IT - I KNOW IT BUMMED ME OUT WHEN SOME ONE SWITCHED GAS ON ME - ONLY TOOK ONE TANK TO SCORE PISTON & CYL.
