Digital readout
Digital readout
Does anyone know of a company that makes a digital display I can use in my truck that will tell temprature, volts, amps by using a remote shunt, and have a backlight and data logger. LCD display perfered but LED will work.
I want to be able to tell the transmission temprature both pre and post cooler, show battery voltage from 2 diffrent sources and be able to monitor the output of the alternator's amps. It should be able to display about 6 lines of text or scroll. I am running out of room in the cab and I need more insturmentation, something like a trip computer but not one, Just simple readout I could build into the dash or surface mount.
Display would look something like this:
Volts #1 12.0
Volts #2 12.0
Amps 50.0
Trans.Pre 230*
Trans.Post 200*
I have checked catalogs but I have only found the components to build my own.
Jim.
Volts #1 12.0
Volts #2 12.0
Amps 50.0
Trans.Pre 230*
Trans.Post 200*
Jim.
Garrett5462
11-08-2007 05:34 PM
mitchkim
20
01-16-2005 08:47 PM
Dodgezilla
01-21-2004 11:24 AM
jrs_dodge_diesel
01-19-2004 10:18 PM
