Coffee Makers
Coffee Makers
Looking to see what you guys use to make you coffee while camping (ie. on a stove).
Getting ready for next years hunt.... Looking at wall tents and stoves...
P.S. No cheating....NO GENERATORS OR ELECTRIC Makers
I have a 1 qt pan with tripod that I used when I would rough it. Heat water then add Sanka or Folgers instant, good enough for me while in the bush.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
perculator over the fire. the old type. still have it and over 20 years old! makes killer coffee but make sure you have a filter or you will have cowboy coffee.
Get a french press. All you need is water that is about 200 degrees which isn't quite boiling. Put your grounds in the press and pour in the water. After about 4 minutes stir it around and press the filter down. Fresh coffee.
Its dirtier than drip, but way cleaner than cowboy! I actually use a french press everyday so there is no need for a big ol clunker on the counter.
Have a good one.
Have a good one.
I don't know what you call it, but I always just put an 'ample' supply of coffee in a deep pan with water and boiled it for 10 minutes or so, then pour it thru a coffee filter into my cup.
chaikwa.
chaikwa.
It's all about the camp percolator, although I don't use a filter with it, I kinda like the cowboy coffee when I'm camping. Makes great coffee, if I could find a decent home perc. for a good price I'd rock one in the kitchen also. Just my $.02
HEY HEY HEY !!!!! -
Cowboys are not dirty. They are strong!!!!!
Filters are for wimps!!!!
Oh ya, I use one of those percolator thingys too. Start it when you get there and just keep addin grounds till you go home.
I have a stainless percolator. Sent it on the stove, set it on the fire.
Mexican Nescafe is a good option when you can't make regular coffee. It's instant coffee that doesn't taste awful. This is different stuff than standard issue Nescafe.
You can find it in most Wal-Marts in the "Ethnic foods" section. It's in a glass jar and the label says "Nescafe Clasico".
