CB needs a little boost
Need a little advise....I have a Cobra tuned and tweaked with Firestix antenna and SWR set at 1.3...gettin ready to put a 250 watt kicker in....I have 10 gauge wire run for the power into the engine compartment where can I tap for key switch power ?? and what size coax should I use from the kicker to the antenna ??<br><br>I have a Astatic RD104E NC Power Mic should I run pre-amp on the kicker with this Mic
Re:CB needs a little boost
[quote author=pappyman link=board=10;threadid=11762;start=0#111505 date=1046794555]<br>Need a little advise....I have a Cobra tuned and tweaked with Firestix antenna and SWR set at 1.3...gettin ready to put a 250 watt kicker in....I have 10 gauge wire run for the power into the engine compartment where can I tap for key switch power ?? and what size coax should I use from the kicker to the antenna ??<br><br>I have a Astatic RD104E NC Power Mic should I run pre-amp on the kicker with this Mic<br>[/quote]<br><br>First of all take it back to your technician that "tuned and tweaked" the radio and ask if you need any more mods to run that kicker. Around my area you need what's called a Super Mod to run a kicker. Not sure what it entails but I know if you don't do it you'll burn up the radio. <br><br>As far as the wire if your just running a lil' 2 pill kicker like that you should be alright with 10ga but you might want to jump down to 8ga if you don't already have the wire.<br><br>As far as power source. If you really wanting to boost the power of your CB then wire it directly to the batter and wire the kicker to the battery too. But run a good ground from the battery to the frame.
DakotaKid287
10-22-2008 05:58 PM
corn binder
12-02-2006 10:24 PM
moparguy
02-27-2005 07:32 PM
