Best way to take window tint off...
Old 01-12-2006 | 10:36 PM
one54ton's Avatar
What is the best way. My current tint needs to go!
Old 01-12-2006 | 10:40 PM
siotwo's Avatar
Pull it off and then use a new razor blade to clean off the glue. Some goof-off will work on the stubborn spots, but use it sparingly. Soapy water helps too.
Old 01-12-2006 | 10:42 PM
TxDiesel007's Avatar
ive taken tint off before
I use just soap, water and one of those blade deals. Just start at a corner, and keep the glass moist..
Tx
Old 01-12-2006 | 10:49 PM
gerry's Avatar
Go to the hardware store and get some of that thin Plastic drop cloth stuff (or go to the dry cleaners and get some of that thin plastic they cover clothes in). Wet tint with soapy water and place the plastic on the window.. This will cause the tint to sweat between the glass and the tint and help release the adheasive.. Pull it off and then clean what little is left with a new razor blade..
Gerry
Old 01-13-2006 | 01:51 AM
I PASS GAS's Avatar
The best way I have found is to spray the tint heavily with amonia. Keep it wet the whole time. It will penetrate the film and soften the glue. With a bunch of new razors, it will come off very easy. The fumes will get to you if your not carefull, so make sure your in a well ventelated area.
Old 01-13-2006 | 02:29 AM
greasemonki's Avatar
You may also consider using a heat gun and a razor. If it gets too hot, the film tends to break, but the heat lossens the adhesive, so the trick is to get it hot enough to melt the glue, but not hot enough to melt the film.
Old 01-13-2006 | 07:51 AM
2500CTD's Avatar
Yip the heat gun works, and also on the plastic film trick, it works better if you park the truck in the sun. The heat and plastic film helps soften the glue faster. I used this trick to detint a rear window with defroster lines. I save the liner from the windows I tint to remove tint if I have to.
Old 01-13-2006 | 08:11 AM
TAS05CTD610's Avatar
Tint
Depends on how good the tint is. My last tint job was good. grabbed the sheet and in one pull tore off all the tint. Sprayed the glue with amonia, waited 10 minutes and scraped the glue off. Cleaned up with some windex and done, about 15 min a window. Worked great.
Old 01-13-2006 | 12:36 PM
Herrin811's Avatar
Ammonia....Guy at the tinit shop told me to never, under any circumstances use an ammonia based glass cleaner, cause it would kill the tint....
Old 01-13-2006 | 12:46 PM
04ctd's Avatar
Originally Posted by Herrin821
Ammonia.... would kill the tint....
it takes the tint out...why you used to see so many cars with purple windows.
you can do it a couple times if you want to lighten your tint.
putting the light plastic film on it, and make it wet, let it sweat, usually best way if tint is old...it'll rip into peices if you just try to pull it.
Old 01-13-2006 | 12:57 PM
P.J's Avatar
P.J
First reply was on the money.
Either "Goo-Gone" or "Goof Off" and some razors. Keep a rag handy, wipe the adhesive with the solvent and scrape off.
Be careful!
Old 01-13-2006 | 03:06 PM
Hillbilly_Deluxe's Avatar
A good way to get the left over glue of is a rag with gasoline. Stinks but It works good.
Old 01-13-2006 | 03:10 PM
P.J's Avatar
P.J
Uh, Yeah, might want to refrain from smoking during that process.
CumminsRedneck
11-22-2007 06:42 PM
one54ton
24
09-07-2005 12:19 PM
mamajo
02-11-2005 09:22 AM
mdq
06-24-2003 04:14 PM
Silverram03
03-19-2003 11:49 AM
