AutoCAD 2005/2006 users, Please Help!
Ok. Figured it out, for those of you that give a flip.
When saving a .dwt file for use as a plot style map for the publish command in AutoCAD 2005/2006, you must type 'pagesetup' in the command line while in your .dwt file and setup the printer formats. You can even set up multiple formats in the same file. Then, when you import the .dwt while using publish, you can select from the different format you set up to print and go.
I tripped on the answer while wadding through the mindless help files.
JWB
JWB
That will work with the 2004 version as well if I am not correct tell me. Seems like you can set all the pages to print the same way, and setup a plot file with all the files you have changed over, and it will plot them like the publish function of the newer version.
justagoodolboy
01-16-2009 07:32 PM
BCarmicle
09-14-2005 07:27 PM
